E4OD rear case bushing
Old Mar 11, 2015 | 07:08 PM
tonyjklh's Avatar
tonyjklh
ok so I'm part way through my rebuild and have a bit of an issue. I installed the sonnax one piece rear case bushing, and I used the sonnax tool to install it. the problem is the output shaft is very tight with it now. has anyone else used the sonnax bushing and had this problem?
I can turn it by hand, but it is tough to turn. when installing the shaft it feels real good until it gets to the forward half of the bushing, this is where it gets tight. should I take it out and use the OE style bushings? or do you think it will be fine?
I should also note that although it is tight, its very smooth as well and doesn't seem to be binding. it was also pretty tough installing so I hope I wont have to remove it as I don't expect it to come back out too easy.
wwhite
Apr 12, 2019 11:13 AM
svspeeder
Feb 21, 2018 03:59 PM
jWoDal
Jul 27, 2011 01:58 PM
rpatrick
Jul 11, 2011 06:46 PM
xlt4wd90
Aerostar
24
Mar 8, 2010 04:57 PM
