292 piston clearance
Old Mar 11, 2015 | 01:49 PM
Jack DK's Avatar
Jack DK
hi
Can somebody tell what the piston to bore clearance is for a 292
Bought a stock style set of pistons, there are no info in box.
Pistons are to be used in a 272 block, bored to fit STD 292 pistons
There is some difference in piston diameter is that normal.
Cylinders need to be bored specific for each piston.
Thanks for experts advice
Old Mar 11, 2015 | 04:04 PM
hiball3985's Avatar
hiball3985
piston to bore clearance-bottom of skirt .0009-.0015
Old Mar 12, 2015 | 03:24 PM
charliemccraney's Avatar
charliemccraney
Best to consult the manufacturer of the pistons, if possible. If they are original Ford, go by the shop manual. If the manufacturer is not known, take it to the machinist and maybe they can use their best judgement.
Old Mar 13, 2015 | 04:48 PM
hiball3985's Avatar
hiball3985
I should have noted the clearance I posted was from the factory manual for factory pistons..
cypher02334
Jun 3, 2015 10:40 PM
rsheffield
1997 - 2003 F150
Dec 29, 2013 11:25 AM
rnelson664
Oct 21, 2007 10:59 AM
bbfbronco
Apr 27, 2007 10:47 PM
