overheating at idle
Old Mar 10, 2015 | 09:08 AM
garretttt4's Avatar
garretttt4
overheating at idle
77 f150 ranger xlt with a freshly rebuilt 460, c6 trans, 4wd, electric fan, new shroud. Its overheating at idle, when I'm driving it sits at about 180-200 but as soon as I stop at a long light, or if I let it idle like if someone is looking at it or anything it starts creeping up almost instantly. I put some water cooler additive in it that someone local said to try and it didn't make any noticeable difference. Anyone know what else to try? High pressure water pump or something?
Old Mar 10, 2015 | 09:26 AM
greentruck72's Avatar
greentruck72
what is your cuurent weather like, and whats the thermostat rated at might not be opening( could be getting cloged up- not likely), high flow water pump may help, take a hose and spray the fins on the radiator( through the grill or in the engine compartment dirt may be in there), are your valves burnt, when was your last rebuild on the engine itsself. are you useing the stock fan wiht the electric or just the electric?
Old Mar 10, 2015 | 01:18 PM
garretttt4's Avatar
garretttt4
Its 55° right now. Thermostat has been taken out. Going to spray the radiator tonight. It all has less than 1500 miles on the rebuild. Just the electric.
Old Mar 10, 2015 | 01:35 PM
greentruck72
yeah other than that i dunno what you could try to me that is the basic list of things to check. on the question of the electric fan( for me personally) how well do they work and what size is yours?
Old Mar 10, 2015 | 01:59 PM
greentruck72
another thing i thought about, is the water pump the stock factory one or is it a newer replacement, some old types were low flow and some high flow( dont hold me to this ), most new are high flow
Old Mar 10, 2015 | 02:15 PM
ShaneNP123's Avatar
ShaneNP123
How far oversize is it bored out?
Old Mar 10, 2015 | 02:37 PM
HIO Silver's Avatar
HIO Silver
200° or even 210° isn't overheating per se... what temp does it climb to when just idling in place for an extended period of time with just the mechanical fan?
And your reading the temp from an actual gauge, right? Not the factory guesstimate gauge?
Old Mar 10, 2015 | 03:20 PM
gatorfor88's Avatar
gatorfor88
And you are running antifreeze?
Old Mar 10, 2015 | 09:34 PM
Blue and White's Avatar
Blue and White
I don't believe you posted fan type. Cool running and hot idling often means inadequate fan air flow. Common after market fans often do not provide the air flow needed at idle. OE type fans, used or re-pop are best. I understand the MK IV or Taurus fans work well... though the mechanical fan + clutch works pretty well in my application. A higher capacity radiator always helps... but may not be the problem in your application.
Old Mar 10, 2015 | 10:16 PM
redneck_davis's Avatar
redneck_davis
What condition is the rad in? Has it been flushed lately? Have any pictures of your fan/shroud setup?
What all ,if anything else is wired in with your electric fan that might be stealing juice?
Timing set correctly?
Old Mar 11, 2015 | 12:00 AM
SlikWillie's Avatar
SlikWillie
This is what I recommend- start by reinstalling a new thermostat and put the mechanical fan back in. This way you can narrow it down to either the electric fan not being big enough or it's a pump problem. Reguardless of weather, that 460 needs a thermostat. Just because an electric fan pulls 3000cfm doesn't mean that it's enough to cool 500 ponies. If the engine is high horse power, consider an aluminum radiator. I see guys all the time throw 5-7000 dollars at an engine and run a stock 2 core radiator and wonder why coolant is boiling out the rad.
FrankGRUN
65
Nov 6, 2018 09:32 AM
abyars111
Jul 26, 2013 11:10 PM
Alter Ego
Mar 11, 2009 02:20 PM
rabbitearscarver
May 23, 2006 04:21 PM
mandm
Aug 27, 1999 05:24 PM
