Accidentally fixed rough idle
Old Mar 10, 2015 | 08:55 AM
ford fisherman's Avatar
ford fisherman
Replaced the rotted gas tank filler line and it smoothed out my rough low speed idle. I tried chasing this problem down a couple of times to no avail and solved it accidentally. Awesome.
Old Mar 10, 2015 | 10:01 AM
puttster's Avatar
puttster
At least you know what you did!
Old Mar 11, 2015 | 10:11 AM
pawpaw's Avatar
pawpaw
Good find & feedback on your repair also fixing the rough idle.
An air leak on that side of the gas cap lets more air into the tank where the vapor recovery system is storing gas fumes in the charcoal canister & sucking them out to help quicken up cold starts, ect, so any extra air/leak in the mix will also corrupt the system calculated for gas cap venting, causing too much air to be in the mix, All a vicious fine tuned circle!!!!
Old Mar 11, 2015 | 08:40 PM
BusBoy52's Avatar
BusBoy52
Air leaks or vacuum leaks in the 3.0 system are a nightmare....rough idle, check engine light, mileage etc....never ending cycle and hard to pin point....thanks for the input!
Old Mar 11, 2015 | 10:41 PM
Mikeman's Avatar
Mikeman
Who'd a thunk? If I ever have this problem, I hope I remember this. I need a way to pound this into my long-term memory, but the old hard drive is getting full.
Thanks for the education.
Old Mar 13, 2015 | 09:58 AM
pawpaw's Avatar
pawpaw
Click on the scales, just to the right of the window post number, to give members reputation points on posts we find helpful.
Old Mar 15, 2015 | 04:32 PM
Mikeman's Avatar
Mikeman
Oh, is that how that works? Didn't know that until now.
Old Mar 19, 2015 | 10:00 AM
ford fisherman
Thanks, did not know that either about the scales.
82lightspruce
Dec 8, 2017 10:20 AM
ranger_runner
Sep 23, 2009 11:02 AM
EZLariat
2004 - 2008 F150
Apr 3, 2006 05:11 AM
medicman
Jan 17, 2003 09:01 AM
bodyelite
Sep 18, 2002 05:38 PM
