2000 excursion no 4x4
Old Mar 12, 2015 | 01:16 PM
Late96's Avatar
Late96
This is what led up to current problem, thirst I can remember. I switched it from 2 WD into 4 WD and it didn't lock in. I went back to 2 then back to 4 WD and it still didn't lock in I switched it to 4 low and "low range" lit up on the dash. I switched it back to 4 WD and 4 x 4 lit up on dash. Switched it back to 2 WD and nothing changed and that is where it is now.
Old Mar 12, 2015 | 01:50 PM
05MilMachine's Avatar
05MilMachine
So did it actually go into 4 low or high or are you just going by the lights on the dash?
Old Mar 12, 2015 | 06:25 PM
Late96's Avatar
Late96
Definitly in 4low
Old Mar 17, 2015 | 05:40 PM
Late96's Avatar
Late96
So dealer said switch and switch only!! Well guess what, still in 4 low. Is there a diagnostic chart somewhere to go by? Thanks
Old Mar 18, 2015 | 10:31 AM
Late96's Avatar
Late96
Not sure how everything works, did some checking and I have 12 volts at 2 wire plug in at actuator even with key in off position.
Old Mar 18, 2015 | 10:49 AM
05MilMachine
Sounds like possibly your relays are stuck, wiring is bad or your gem module. If you take out both relays, that voltage should go away at the actuator and allow you to remove the actuator, then manually move the tcase to 2wd. You can use voltage on some leads to drive the motor back to 2wd position then stick it back in. As long as you don't plug in the relays, you should at least be able to drive it in 2wd.
Old Mar 18, 2015 | 11:20 AM
Late96's Avatar
Late96
I've switched relays around with no help, I need the option of 4high as snow goose hunting is on and fields are muddy. What terminals do I apply voltage to to manually shift motor back to 2 wheel drive? Where is this GEM located? Maybe try a tap test on it. Thanks
Old Mar 18, 2015 | 11:38 AM
harley4jcs's Avatar
harley4jcs
Pull both relays & test for power at the shift motor switch..
Old Mar 18, 2015 | 05:15 PM
Late96's Avatar
Late96
Removed relay power went away, how do I make motor go back to 2 high? How do I determine what is the culprit now? Thanks
Old Mar 18, 2015 | 06:19 PM
05MilMachine
Well, you need a diagram to see which two wires drive the motor. Reverse the polarity and it should drive back the other way. I assumed if you were testing for power, you knew which two pins. I don't have a schematic or I would offer it up. Sorry!
Old Mar 18, 2015 | 07:12 PM
Late96's Avatar
Late96
I don't have diagram either, There are only 2 wires going to motor labled A and B. B was the one that was powered all the time
Old Mar 18, 2015 | 08:12 PM
05MilMachine
Well its a dc motor, so if there are only two pins, then you should apply 12 volts using pin a as your positive. Should drive the other way. I used a drill battery on my old 97 f150 when its gem died.
Old Mar 19, 2015 | 06:11 AM
  #28
Late96's Avatar
Late96
So are you suggesting GEM module?
Old Mar 19, 2015 | 07:51 AM
  #29
05MilMachine
I'm saying its a possibility. My gem died on my truck and the motor would not move. It had been getting wet from a minor windshield leak that I didn't know I had. If your wires check out ok and your relays are both good and your switch and actuator are both new, there isn't much left.
Old Mar 24, 2015 | 07:38 AM
  #30
Late96's Avatar
Late96
Still trying to find a module, don't really want to spend what ford wants just to try. To the best of my knowledge wiring is good and grounds are good. But still energized relay.
