Washington Chapter Washington Chapter
Join Chapter, Leader: Tim Young
Hello Washington folks
Old Apr 24, 2015 | 04:14 AM
  #31
GruesomeJeans's Avatar
GruesomeJeans
I'd be happy if it starts and runs reliably and smooth. Maybe gets more than 8mpg. I think my intake played the biggest part in that issue.
I'm not sure how my Carter is set up. I doubt its set for a larger engine.
Old Apr 24, 2015 | 04:16 PM
  #32
oddfordjunkie's Avatar
oddfordjunkie
There should be quite a bit of interchange between an AFB and an Edelbrock though I've never bothered looking into it, I bring this up as I have quite a few Jets, Springs and Metering Rods for Edelbrocks.
Old Apr 26, 2015 | 01:48 AM
  #33
GruesomeJeans
Should be but I'm not sure. After the recent intake work I've noticed a leak at the throttle valve thing. It looks like it may be leaking fuel, kind of a brownish color now.
Old Apr 29, 2015 | 12:05 AM
  #34
oddfordjunkie
"thing"
I could give you my buddy Ben's phone number so he could tell you how much that drives me nuts. haha
Fezzik, if you want help tinkering on the truck then the next meet is a work party at my place.
https://www.ford-trucks.com/forums/1...l#post15313028
Old May 1, 2015 | 01:34 AM
  #35
Fezzick's Avatar
Fezzick
Sorry guys, real life has gotten in the way of me fixing up some of the things on the truck lol. Saw the meet up thread I work open to close that day so unless something changes I wont be able to make it, but if I do happen to get that day off I am all in for it. Updates to the truck, I installed an aftermarket tach so I could tune/monitor my rpms, I will post a pic of the results of the install, I believe I did a decent job lol. Fixed my starting issue I had seems the butterfly valve was in a constant open position, so the carb couldn't suck the gas thru to start so I adjusted it to be flat so the choke could do its thing and it starts reliably now with a few cranks of the engine. But I now found a gas leak at my fuel pump at the coupling between the incoming metal line and the screw on fitting. So I am now going to replace that line, the fuel pump and the rubber hoses as well top redo that part of the system so that I dont have to worry about it. I still have not rebuilt the carb lol, but with the pump issues thats now a back burner till I get the other done.
Old May 1, 2015 | 02:25 AM
  #36
oddfordjunkie
Late arrivals on the 20th is just fine. Or pretty much any day of the week is open.
Glad you got a couple of the issues figured out.
What do you do for work?
Old May 20, 2015 | 08:14 AM
  #37
MitchH's Avatar
MitchH
As much as I'd like to make the meet, work comes first. Though if I could met up with someone in the Tacoma area to help me with some tuning of my 71. I was messing with it yesterday and it runs ok but at a stop in gear it seems like it wants to die. As I accelerate it struggles a bit but then takes off fine and runs pretty smooth. I have a 360FE still have points, though I would like to get away from them. Good luck with the meet today!
Old May 21, 2015 | 10:35 PM
  #38
GruesomeJeans
I think you can just get a standard distributor from the store to replace the points right? The only vehicle I had with points was a 71 Volkswagen.
Old May 31, 2015 | 09:54 PM
  #39
oddfordjunkie
Yes, can get a factory replacement Duraspark distributor for a 1976 390cid, drop it in and wire in any ignition system that you want to run.
I could probably meet up with you next time I do a trip up north.
Old Jun 1, 2015 | 09:22 AM
  #40
GruesomeJeans
Speaking of your trip up north, I forgot where its at, if you need help moving stuff for the parts truck or anything else, let us know.
Old Jun 3, 2015 | 05:47 PM
  #41
oddfordjunkie
Parts truck is in Marysville but I usually have a bunch of running around to do every time I'm up there so I wouldn't drag someone along for all of that.
MitchH: You can PM me your cell # when you get enough posts to do PMs and I'll let you know when I'm in the area.
katoranger
Kansas Chapter
35
May 31, 2018 12:08 AM
Jonnyuma
Oregon Chapter
19
Sep 22, 2016 12:35 PM
LibTimothy
Texas Chapter
Sep 1, 2015 04:59 AM
SteveBricks
S. California Chapter
Jul 13, 2012 08:20 PM
camohr
Kentucky Chapter
Dec 26, 2009 09:27 AM
