new here need input
Old Mar 8, 2015 | 12:48 AM
84XLF150's Avatar
84XLF150
new here need input
hey y'all I'm new here i have a 1984 f150 and id like to put 3/4 ton front and rear springs in my truck to support more load I'm a landscaper and need all i can to tow/haul if anyone can tell me what i need to do id greatly appreciate it!!
i already plan to plate the frame and put a new rear axle in the truck what else would i need?
i beams?
mounts?
stuff like that if anyone can help me id very much appreciate it!! thanks!!!
Old Mar 8, 2015 | 01:17 AM
85e150's Avatar
85e150
Welcome to FTE.
To be blunt, you need to sell that F150 and buy an F250 or F350.
Since you are a commercial operator, you would be more susceptible to a vehicle inspection after an accident. Your truck had a GVWR listed for it, and if you exceed that, even with modifications, it could increase your liability.
Axles, tires, brakes etc won't strengthen the frame. And they will not change the GVWR listed on the truck.
Old Mar 8, 2015 | 03:31 AM
trevisM's Avatar
trevisM
Load that half ton heavy and it will break spindles and wheel bearings and even wheels, don't ask how long it took me to learn.
Get a truck that is meant to do what you need done, F350 with a flat bed dump would be my choice.
Old Mar 8, 2015 | 08:05 AM
Gary Lewis's Avatar
Gary Lewis
These guys are telling you the truth. You cannot make a 1/2 ton truck into a 3/4 ton truck for even close to reasonable money. You'd have to replace everything from the ground up, inc wheels, tire's, brakes, axles, springs, frame, master cylinder, etc. And then you'd have a truck that wouldn't be legal to haul what it was capable of hauling.
You really do need to sell that truck and buy a heavier one rated for what you are going to do with it. That will be far, far cheaper and faster to do, and it'll be legal to boot.
Old Mar 8, 2015 | 02:59 PM
trevisM's Avatar
trevisM
I guess it was about twenty years and thirty broken trucks until I got a one ton and I haven't had half ton since. Kinda got used to not working on one twice a week. Miss the thrill of axle coming out on the highway with a load though. Or the time the rear axle broke at the bearing and the wheel/tire passed me. If I want to haul light I use a Crown Vic.
Old Mar 8, 2015 | 03:18 PM
Franklin2's Avatar
Franklin2
You can put decent tires on a f250 or f350 also with a very high load rating.
Old Mar 8, 2015 | 03:24 PM
H311RA151N's Avatar
H311RA151N
The legality issues with an overloaded truck as stated above are pretty serious. The state in which I reside it's a very serious offense. Not to mention expensive.
If you look in your area for a while you can find an F250/350 pretty reasonable. That's what I had to do as well. Kinda stinks waiting but you get what you really need and want that-a-way.
Old Mar 8, 2015 | 10:01 PM
84XLF150's Avatar
84XLF150
id really like to keep the body thats on;y got 2 small dents i would do a chassis swap but I've never found a 2 door short bed f250/350 but thanks for the input guys i appreciate it very much!
Tim Edwards
May 19, 2016 06:00 AM
dnmyoda
Jun 29, 2006 03:20 PM
gl0116
Oct 31, 2004 10:00 PM
jojo41
Jul 30, 2004 03:52 PM
Dustin R
All Things Towing
16
Oct 25, 2002 02:39 PM
