Aerostar Ford Aerostar
Broke Spark Plug
Old Jul 23, 2003 | 10:43 PM
TCruiser's Avatar
TCruiser
Cool Broke Spark Plug
The plug twisted off at the NUT! Drivers side far back one. (92 4.0 V6 Aerostar)
The plugs must have never been changed (165,000mi), virtually nothing left of the electrodes, but it still ran great!
I read here where someone used PB Blaster... awesome stuff.
Here's how I got the plug out.
1. Unbolted and pulled the accelerator pedal out of the way.
2. Drilled 4 holes, and used a reciprocating saw to cut an access hole by the accelerator about the size of a paperback novel.
3. Began to chisel (lightly) and got the porceline part out by lightly chipping, and vacuuming, it finally sucked it out whole. Luckly the tip of plug kept it from dropping into the cylinder.
4. Soaked the rest of the plug with liquid wrench and then began using an extractor that fit in the plug hole, and worked and worked and worked on it for a couple of hours, and was being very forceful... then I gave it a break.
5. Got mad... Bought PB Blaster... sprayed a little on, gave it a tap and an hour of time, then it just came loose with a hard twist. WOW!!!
Hope this helps someone else. I thought I'd have to junk the van.
Old Jul 26, 2003 | 03:35 PM
rebocardo's Avatar
rebocardo
Broke Spark Plug
I do not know what PB Blaster really is, but, it works great! That is the worse plug to change for a tune up and even worse to break. I am glad you got it out as easy as you did.
