very poor start up
Old Mar 7, 2015 | 06:23 PM
Adam.34's Avatar
Adam.34
very poor start up
Okay so I ran my excursion earlier this morning and it ran fine and what have you, and now 6 hours later I got to start it up and it sputters and dies. I start it again and it starts right up but then goes to sputter again and I hit the gas and it didn't respond, the RPM gauge was lingering just under 500 RPMs. I had to hold the gas pedal for about 15-20 seconds before the engine would rev up, it kept doing this till the engine finally warmed up and I drove it up and down my block with barely and throttle and with wide open throttle and it ran fine. With the engine warmed up it started with no problems. I have a 2000 5.4L V8 gas
Old Mar 7, 2015 | 07:31 PM
harley4jcs's Avatar
harley4jcs
I have a V-10 that just did the same thing yesterday. It dose not get a lot of run time right now so I was just going to run it around to keep it up. The temp was close to 24 Degrees out. It shimmied, shook, & died as well for the 1st min or two then all was well. I'm interested to see if you get an answer
Old Mar 8, 2015 | 08:55 AM
Adam.34's Avatar
Adam.34
Nothing yet sadly, does your V10 do it every time you start it up while the engine is cold? Mine just did it again but this time when I revved it, it sounded like it was almost misfiring but its not throwing a code
Old Mar 8, 2015 | 09:21 AM
harley4jcs's Avatar
harley4jcs
1st & only time so far BUT it did exactly what you described your V-10 - 2 did to the T
Old Mar 8, 2015 | 09:35 AM
Adam.34's Avatar
Adam.34
Yes! I found the problem! I didn't think it could be something so simple but my air intake system came off of the throttle body and it was letting to much air into the engine. I was playing with it with the engine running and I moved the air intake over the hole and it ran perfectly, I removed the air intake about halfway off the hole and the engine ran crappy and stalled out. Check your air intake it
Old Mar 8, 2015 | 10:51 AM
harley4jcs's Avatar
harley4jcs
GREAT , I'm glad you got it dicked
motoboy
Dec 9, 2016 09:02 AM
perryg114
Modular V10 (6.8l)
Feb 1, 2015 09:01 AM
silverybullet
Modular V10 (6.8l)
Aug 26, 2009 10:12 AM
H1449-6
Oct 5, 2007 12:13 PM
ddwood55
Modular V10 (6.8l)
Feb 13, 2007 10:39 PM
