Electrical problem
Old Mar 7, 2015 | 05:56 PM
Welder90's Avatar
Welder90
Electrical problem
Alright so my starter solenoid went out and I replaced it and before I started it I charged the battery and when I finally tried to start it it would crank but not run or sputter for just a moment then quickly die so I left the key on and I smelled burning plastic so after I removed the instrument cluster I find a wire it's either pink or red and it's hot that's the only one I found that was burnt and I can't tell where it goes to I was thinking about just replacing the whole wire but I need to know where it leads thanks (I hate wiring so much)
Old Mar 7, 2015 | 05:58 PM
HIO Silver's Avatar
HIO Silver
Go here: 1973-1979 Ford Truck Wiring Diagrams & Schematics - FORDification.net
Thanks.
Old Mar 7, 2015 | 06:09 PM
Welder90's Avatar
Welder90
Geez that's like trying read Braille
Old Mar 7, 2015 | 06:10 PM
Welder90's Avatar
Welder90
I'm guessing it's the resistor wire? Anyone know anything about it?
Old Mar 7, 2015 | 06:12 PM
HIO Silver's Avatar
HIO Silver
If you can read a road map then you can read a schematic.
Click on the image and zoom in.
There is no try. There is only do.
Old Mar 7, 2015 | 06:14 PM
HIO Silver's Avatar
HIO Silver
Yup. It's for the ignition system. It's supposed to provide resistance. But broken or smoke checked wire has EXTREMELY high resistance and no longer works properly.
TheMonson
25
Aug 13, 2018 01:20 PM
Bazookajoe
18
Jul 27, 2015 08:35 AM
American Thunder
1978 - 1996 Big Bronco
Sep 16, 2010 07:59 PM
alexjp91
Nov 19, 2007 10:49 PM
idealtrucks
Mar 5, 2003 08:52 PM
