Vehicle: 96 F-150 xl, 4x4,302, Standard cab, Front end labeled D-44, it has front quad shock option, all factory. e4od trans.
The yoke on the front drivers side outer drive axle broke. need to replace. Also replacing both front end ujoints, all 4 ball joints and bearings.
It was a little clunky in 4wd had all the parts but not the time to get to it, then the yoke busted and now 4wd is not an option. I called around and The only place that can get the axle kit (both pieces) to my area is advance auto but here is the quandary: they asked me what my wheel base was????
Here is a list of their part options:
109441 31 1/4" WB drive shaft assembly $215
109442 39 1/2" WB drive shaft assembly $215
109444 39 1/2" WB e4od 8cyc $215
4R70W 36" drive shaft assembly $215
These are exactly as listed on their computer.
I had no idea that there were 3 wheel base sizes for a dana 40 type front end on a 96 f-150 but, according to their computer, there are
Does anyone know which would fit based on the information I have provided?
I can pull the rest of the numbers from the sticker on the front end, but it is snowing out and I really dont feel like crawling under there until I can get it inside somewhere.
You're right, fool at Advance was giving me drive shaft lengths, not front axle. Thats why they had so many. I specifically told them front axle assembly, I looked it up in the hayes manual before I called them. Well, that was a waste of time. Anybody know where I can get one of these. I tried Bronco graveyard but they are closed for the night.
