multiple degas bottles cracking
Old Mar 5, 2015 | 03:47 PM
samsdad02's Avatar
samsdad02
Has anyone else experienced degas bottles cracking? I have been through at least 2 napa and 2 ford in 2 years. all of them have failed along a reinforcement rib on the bottom above the outlet. new caps at the same time on all of them. never puked. the napa ones failed within months of each other. the ford one that just failed was replaced with a napa one again which lasted 2 months.
again NEVER had a puke.
thanks
Old Mar 5, 2015 | 03:58 PM
dannyboy950's Avatar
dannyboy950
Yep probably a manufactureing defect. We bought 10 at one time when I was with the fleet all failed. Bought 12 more from same dealership no failures. Bad production run I guess. Altho I do not know if Ford got them from the same manufacturer.
Old Mar 5, 2015 | 04:31 PM
samsdad02's Avatar
samsdad02
getting tired of it. napa one is warrantied.
along with the degas, been thru about 6 icp sensors in the past year. Thank God they've been warrantied.
Old Mar 5, 2015 | 04:37 PM
mattdoc88's Avatar
mattdoc88
Mine cracked enough to leak under pressure. It could have been the original, I don't know. I bought the truck with 172k on it, has 183 now.
Old Mar 5, 2015 | 06:38 PM
dannyboy950
Is your ICP on the pump or on the passenger valve cover?
If it is on the pump [early04] you may be cracking it yourself working on the ICP.
Done that myself a few times.
Old Mar 5, 2015 | 08:15 PM
Pocketlint's Avatar
Pocketlint
I would think if the Napa one's are failing at that rate is there is a defect in the manufacturing process that is causing them to leak
If your having that much bad luck with them I would avoid them and either use Ford ones or find a different vendor to but them from ( You would have to watch out that the next one you buy isn't who manufactured them for napa )
But that is brutal, but at least napa is giving you replacements, but if the replacements arent holding up, then I would just get my cash back and look for some where else for a different one.
Old Mar 5, 2015 | 09:49 PM
78fordman's Avatar
78fordman
I had the same problems with the napa ones on my wife's car. Crack for no real reason, new cap each time. Ended up selling the car.
Old Mar 6, 2015 | 12:32 PM
samsdad02's Avatar
samsdad02
went thru a couple of ford ones as well. if this napa one fails, I will be getting an aluminum one off ebay. the down time I have in this to go get a new one and change it out each time will have paid for one already.
Old Mar 6, 2015 | 12:34 PM
samsdad02's Avatar
samsdad02
valve cover.
I carry the combination wrench with me all the time now...
Old Mar 6, 2015 | 12:38 PM
samsdad02's Avatar
samsdad02
this is the one
http://www.ebay.com/itm/ALUMINUM-6-0-powerstroke-degas-tank-/191441911858?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c92d3c032&vxp=mtr
Old Mar 6, 2015 | 01:20 PM
dannyboy950
Wow did not know anybody even made an aluminum degas bottle.
Old Mar 6, 2015 | 02:18 PM
69cj's Avatar
69cj
Nice, how do you monitor the coolant level?
Old Mar 6, 2015 | 03:20 PM
bubba_78363's Avatar
bubba_78363
It kinda looks like those two large bungs on the front of it are sight glasses, but it's hard to tell.
Old Mar 6, 2015 | 03:57 PM
69cj's Avatar
69cj
Since the 6.0 normal level is now the min. level I don't see how you'd know where it's at?
Old Mar 6, 2015 | 04:21 PM
bubba_78363
Agree completely! I don't know if you just keep it middle of the lower bulls-eye or what. Definitely different for sure.
