Ball Joint Service Kit
Old Mar 5, 2015 | 12:22 PM
GocartMozart's Avatar
GocartMozart
I want to give it a go and try to replace the ball joints on my 1995 f-150 4x4. Will this tool work for my application?
Ball Joint Service Kit for 2WD and 4WD Vehicles
Old Mar 5, 2015 | 12:37 PM
Doostien's Avatar
Doostien
Looks like the one I used to do mine, though mine was from Princess Auto. Likely just different packaging.
Be careful when using it though, you can bend the the press if you apply too much pressure. When doing the ball joints if it gets really hard to turn, smack the end of the threaded rod. A good smack usually is enough to knock the ball joint loose.
I used the same tool for my u-joints too, works wonders compared to the socket method.
Old Mar 5, 2015 | 03:11 PM
rugermack's Avatar
rugermack
Same one I used, ball joints, pivot bushings
Old Mar 5, 2015 | 05:00 PM
jaagen's Avatar
jaagen
If your only going to use it 1 or 2 times you can rent them at like O'riellys or autozone. That's what I did for my truck
Old Mar 5, 2015 | 05:14 PM
fordboy97's Avatar
fordboy97
That's what I did too. I did my ball joints recently. I recommend Moog they are high quality.
Old Mar 5, 2015 | 06:56 PM
GocartMozart
Thanks for the advice. I was looking at Moog, good to know they are recommended. I am also thinking that buying the C-clamp press might be handy for other applications as well (for example, wheel bearings, wheel students, maybe for removing the bushings in the rear leaf springs). I have a bunch of work to do.
Old Mar 5, 2015 | 10:18 PM
jaagen's Avatar
jaagen
I also recommend moog parts. That's what I used for my upper and lowers
mgmoore7
Sep 18, 2016 09:00 PM
yoslick
Dec 2, 2012 08:17 AM
mwsF250
Nov 3, 2010 07:19 PM
CarlF250
Mar 13, 2008 02:25 PM
handsomerob
Sep 13, 2007 06:23 PM
