compression test results
Old Mar 7, 2015 | 01:48 PM
gatorfor88's Avatar
gatorfor88
first thing to do would be to get it at tdc on number 1 piston. then pull distributor cap off and see if rotor is close to number 1 on the cap
Old Mar 7, 2015 | 02:05 PM
xxkenny90xx's Avatar
xxkenny90xx
Yes I've done that and its dead on
Old Mar 7, 2015 | 06:38 PM
redneck_davis's Avatar
redneck_davis
Trying 180 out from there wouldnt be a bad idea. To check and see I the top dead center is of comp or of exhaust..stick your finger in the spark plug hole to seal it and as the piston comes up see if its building pressure
When you're lined up on what you think is tdc , check your timing marks on the harmonic balancer
Old Mar 7, 2015 | 11:27 PM
EP145's Avatar
EP145
Also check your plug wires and make sure they are in the right order.
1960fordf350
13
Feb 10, 2019 01:30 PM
krazyness
Feb 25, 2016 09:09 PM
lewislynn
Jun 6, 2009 11:31 AM
Ranger1F150
31
Apr 9, 2007 01:31 PM
350ford4x4
Aug 29, 2006 08:57 PM
