Battery keeps going dead
Old Jul 23, 2003 | 07:39 PM
wes_shepherd's Avatar
wes_shepherd
I have a 1966 ford f-100. It starts up and drives fine but after i let it sit for a day or two the battery goes dead. I know it isnt the alternator because the guage show the battery is charging. I replaced the voltage regulator. I checked the wires to see if there was a short anywhere but still couldnt find anything bad. What else could it be? What wires should i check for a short?
Any help would be greatly apprecieted,
Thanks,
~Wes
Old Jul 23, 2003 | 10:22 PM
Rosati's Avatar
Rosati
Turn the ignition off and disconnect the negative cable from the battery. Hook up a voltmeter or test lamp between the battery and negative cable. If voltage is present or the light glows, you have current draining the battery.
Now pull one fuse at a time until the light or voltage goes off. Now you can trace your short.
Old Jul 23, 2003 | 10:24 PM
airharley's Avatar
airharley
I had a problem at my firewall connections with my power drain. Look to see that you don't have any corrosion in the connections. A rifle bore cleaning brush does wonders. Also do you have a volt meter? You can do a key off voltage check on your wires to see if you have an accessory draining it. Just for another option.
Old Jul 23, 2003 | 10:26 PM
wes_shepherd
Thanks alot guys. All try both tomoroww and let you know.
Thanks,
Wes
Wes(MI)
Large Truck
Feb 25, 2017 03:40 PM
WesB96F150
Jul 24, 2009 11:04 AM
Doormatt
Electrical Systems/Wiring
Nov 26, 2006 10:19 AM
WesDoss
1978 - 1996 Big Bronco
Oct 1, 2004 05:06 PM
1987tc
1983 - 2012 Ranger & B-Series
Dec 7, 2002 11:45 PM
