Idle increase aut.
1.Idle automatically increases. Touching the brake or gas pedal brings the engine idle to a normal level. Is that normal (factory settings for warm up) ?
2.White exhaust smoke occasionally appears. Making the truck looking like a steaming locomotive. Rpm + 2500 and its gone again, and I wont see the smoke for the next couple of weeks. Is that normal? Self cleaning or something like that.? Also the truck smells a bit warm/burned when it pops the white smoke.
3.Mirror expansion dont work anymore...could it be just a Fuse or is this function blessed with a weak engineering spot some where..?
Insightful guidance is much appreciated. Cheers
2. Sounds like it's in regen. Does it say anything on the dash when smoking?
3. Could be a fuse, switch, or failed. I assume by expansion you mean into tow mode, not folding in or out?
