7.3 help
Old Mar 4, 2015 | 06:03 PM
fordman67's Avatar
fordman67
Lol bag over drivers head lol
Old Mar 5, 2015 | 04:42 PM
hendrix84's Avatar
hendrix84
1994.5 F350 7.3 no start
I have a 1994.5 7.3 I put a new fuel gally pump in it will turn over but won't start it will pull start and run great what's your best guess where shuld I start
Old Mar 5, 2015 | 10:52 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
welcome to the forum. For a new problem your best bet is to start a new thread. Can you tell how fast it is turning over while cranking? Have you checked the battery connections including the grounds on the block? Have you load tested the batteries? Fuel pressure should be a minimum of 20 psi while cranking and can be checked from the schreader valve on the fuel bowl with a tire gauge. Good luck
Old Mar 6, 2015 | 08:02 AM
thomabb's Avatar
thomabb
Bump start but no fire with starter. Sounds like there isn't enough amps to turn the starter and fire the injectors. That is where I would go first.
Old Mar 6, 2015 | 08:03 AM
thomabb's Avatar
thomabb
Measure the volts across the battery terminals while the starter is cranking and report back...
six6six
31
Mar 29, 2021 07:14 AM
1a2a3a
21
Jul 6, 2015 04:53 PM
Powerstroker96
Mar 2, 2008 08:21 PM
Hiflyer746
Sep 27, 2006 08:21 PM
Dieseladdict
Nov 21, 2005 02:04 AM
