Balancer Recommendations
Old Mar 1, 2015 | 09:28 PM
Boba Fett's Avatar
Boba Fett
I am need a 28 oz balancer that will work with a Fox Mustang 5.0 HO serpentine setup. Not looking for an SFI unit either. What are you guys using for your builds?
Old Mar 4, 2015 | 01:44 PM
bkaul's Avatar
bkaul
Both the 28-oz and the 50-oz balancers have the same crank pulley bolt pattern. The Fox Mustang serpentine crank pulley should bolt right up, no problem.
Old Mar 10, 2015 | 11:08 AM
bkaul's Avatar
bkaul
I should note some of the really old balancers had 3-bolt patterns instead of 4-bolt; there are adapters available for that, and spacers to get the right belt alignment if necessary. But there are both 28 and 50-oz balancers available with the 4-bolt pattern that will work for the Mustang setup.
GreyScar
Jan 8, 2019 12:06 PM
Farmerjeff
Dec 29, 2016 09:16 AM
FordPUs
Dec 14, 2005 02:32 PM
