Tapping reduced
Today, I drained the oil. I had less than 500 miles on it and the filter. I put another filter on it and put Rotella T 15w40 diesel oil in it. No additional additives.
The tapping was gone within a few minutes of idling, but the light ticking persists. I'm not concerned with the valve ticking. The tapping (not knocking), annoyed me. Just a quick note for anyone else experiencing similar issues.
Generally speaking heavier oils will provide a thicker oil film, reducing metal-to-metal contact.
Your tapping noises, sometimes referred to as "valve train hash", also drive engineers nutz. It can emanate from so many creaky parts that it may be very hard to pin down the exact source. I've had to tell friends "Don't worry about it - it may be annoying but it won't affect function. If it is something critical it will eventually grow in intensity and make itself known and then you can deal with it".
Years ago, I had a 1984 F150 with 4.9L engine [now belongs to my son]. The engine had ~85K easy miles and was in great shape. I was offered a free oil change in exchange for a favor to a shop owner.
I chose 10W30 Mobil 1 with a Motorcraft FL-1A filter. Immediately, upon start-up, the lifters clicked. They had never done that before. The answer was that synthetic oils are "thinner" than conventional oils. I am not talking about viscosity [or perhaps I am], since the 10W30 is what is recommended... grab an unopened quart of 10W30 synthetic in one hand and hold a quart of conventional 10W30 oil in the opposite hand. Rock them back and forth and feel which one "sloshes" more readily. This may be what is referred to as "pour point"?
This is why synthetic oils are so good in very cold climates.
By the way, that same engine does not display any lifter noise when using Rotella T5, which is a 10W30 synthetic blend.
However, I didn't just jump right into 100% synthetic, each oil change I would mix the oils, like 1/3 synthetic and 2/3 dino to let the synthetic clean out the engine untill I was full synthetic. Doing it gradually is much better, but if you had to jump right into it, I'd replace the oil filter a few times because the synthetic is gonna clean the crap out that's holding it together.
