Everyone here seems to do the modded b spring but I decided to go against the grain and try the pro comp 22415 4" lift springs. They're inexpensive so if I don't like them it's no big deal. My question is has anyone here installed the procomp springs and what size u bolts did you use?
The reason you see such a following for the Moded B Codes is most here tow heavy loads & are not trying to add a 4" -6" lift. Only fix a factory design problem. When you go to a spring as the Pro Comp you more than likely are reducing your load/towing capacity. What are you going to do up front ???
I'm going with bags to take care of towing capacity. The front has a shackle lift on it not sure if they're stock springs or not but it's fairly stiff. Until I notice something negative it'll probably stay as is
I've been running the Procomp 22210(front)/22415(rear) springs for about 4 years now. I tow a around 8k Lbs with no problem.
How much lift did the 22210s give you ? I'm considering them, but have read where they have given some Ex owners 5+ inches of lift and that is actually more than I want.
I did gain about 5" with this combo. I removed the factory blocks and the truck sits level. It doesn't seem to be to high for me. It's actually about the height of a stock F250/350. Maybe a little bit higher but not much. I don't know how to add a pic on here so if you want to PM me your e-mail I can send you a few pics
That looks great! Looks about the same height as mine. Currently have a 4" block and the stock 2" block in back so I'm hoping the 22415 will get me the same lift with no blocks
As in you have stacked blocks? That's the sketchiest and most dangerous way to get lift there is.
