Excursion Transmission Problem
Old Jul 23, 2003 | 04:21 PM
zoloent's Avatar
zoloent
I have a 2001 Excursion 4 X 4, with the 7.3 Diesel engine. Before the 36,000 mile warranty expired I took it to the dealer and had it serviced and inspected, and no problems were found.
I just turned 41,000 miles and up to now I have had no problems. A few days ago when returning to LA from Las Vegas, the outside temp was 114, I noticed that the engine service soon light had come on. A few minutes later the overdrive light on the shifter started to blink. So I tried to reset it but it would not reset.
I stopped at a truck stop and checked the trans oil level which was OK. When I started to leave the startion, I noticed that the trans was starting to slip in first gear. but once it shifted into second gear, it seams to be OK.
I took it to the dealer the next day and I got a rude awakening!
The 100,000 mile powertrain warranty does not cover the transmission, and the bumper to bumper warranty expired at 36,000 miles.
I was told by the dealer that when they put the test computer on the system, 6 trouble codes came up. all related to the transmission, and that the trans needs a total overhaul or a new factory trans, all at my expense.
The dealer can not tell me what caused the problem only that the trans has to be replaced.
Does anyone have any suggestions???
e-mail me at zoloent@juno.com
Thanks,
zoloent
Old Aug 11, 2005 | 08:58 AM
LTW's Avatar
LTW
I am having the same problem ... 2003 Excursion. At about 35,000 miles had to have transmission replaced because it was hesitating when shifting from reverse to drive - FOrd replaced under warranty. Now at about 45000 miles the OD light is flashing and check engine light is on, a mechanic friend checked out error codes and said it was some kind of shift solenoid. Haven't been to Ford yet but I'm sure it won't be covered under warranty.
Old Aug 11, 2005 | 09:40 AM
roaky81's Avatar
roaky81
I had a problem with my 93 tranny, it would get "confused" at highway speed in O.D. It would shift in and out of O.D., took it to a Aamco shop and they found that the sensor for the gear selector (on the tranny) was bad. Your problem is a little different so I'd remove the tranny dipstick and smell the fluid. If it smells burnt, then you are in deep doodoo. If not, I'd take it to a reliable trans shop and have them troubleshoot it. As everyone here will say, high temperatures is very bad on trannies, they usually add a bigger cooler to their vehicles.
Old Aug 11, 2005 | 09:42 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
