No start
Old Feb 28, 2015 | 02:09 PM
Travis Dean Bush's Avatar
Travis Dean Bush
No start
Alright i have a 97 f250 7.3 turbo diesel, as i was driving the other day the truck shut off as i came to a stop light and would not start back up. The truck seems to bot be getting fuel but the pump works and the filter is full. There is no smoke coming out as i crank, any suggestions?
Old Feb 28, 2015 | 02:31 PM
madMatador78's Avatar
madMatador78
Check fuse 22 under the hood. Are you getting a wait to start light?
Edit: By the way, welcome to FTE!
Old Feb 28, 2015 | 03:05 PM
MI02SVT's Avatar
MI02SVT
Do you have a spare cps to swap in
Old Feb 28, 2015 | 08:26 PM
ReBilld's Avatar
ReBilld
Welcome to FTE! X2 on the CPS. That's where I would go next after checking fuse 22 like Thomas suggested.
Old Mar 2, 2015 | 12:18 PM
Travis Dean Bush
I will go look at the fuse and no the wts light quit coming on
Old Mar 2, 2015 | 12:20 PM
Travis Dean Bush
Also i have already switched the cps and that didnt work
Old Mar 2, 2015 | 12:21 PM
cowmilker08's Avatar
cowmilker08
Fuel bowl heater maybe have shorted out and blew the fuse. Its the same one the powers the pcm. If the fuse is blown unplug the fuel heater and put a new fuse in.
Old Mar 2, 2015 | 12:27 PM
Travis Dean Bush
Fuse 22 is blown i replaced it and it popped again
Old Mar 2, 2015 | 12:29 PM
cowmilker08
You need to unplug the fuel bowl heater. I'm spacing out on which plug it is exactly, but I think its the middle one on the driver's side of the bowl.
Erics Truck
Oct 31, 2020 05:12 PM
Spool&Go
Dec 26, 2011 09:45 PM
ralphy_2002us
Dec 8, 2010 06:46 PM
liveoak
Aug 1, 2009 01:23 PM
brad7.3
32
Feb 7, 2009 10:30 PM
