missing dummy lights
Old Feb 28, 2015 | 09:26 AM
pilgrimbizket's Avatar
pilgrimbizket
Ive owned this truck 3 years come may already put 20k on her.
Alot since this is my hunting and travel truck.
Anyways since day one of my ownership there has been no parking brake light, or low fuel light. I really dont need them just want to know if I have bulbs burnt out somewhere.
Thanks in advance
Old Feb 28, 2015 | 09:48 AM
farmert's Avatar
farmert
No low fuel light on these trucks. The light that comes on for the park brake is in the wait to start area, and should come on if you have low vacume, low fluid in the master brake cyilnder or some other brake failure/problem, along when the park brake is applied. Maybe the wire has come off of the switch on the park brake. It is a simple one wire that grounds when the peddle is depressed.
Old Feb 28, 2015 | 10:25 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
On the top of the park brake pedal assembly there is a small wire that connects to it. Apply the park brake and give the wire a good solid wiggle around while watching the gauge cluster right below your tach. If you see he light blink it is that switch that's your problem
Old Feb 28, 2015 | 10:49 AM
pilgrimbizket
Thanks guys, when I get back to CA I will address this after I get the truck running. I will report back after its corrected
RA101725
13
Aug 28, 2019 06:26 PM
silar
Sep 22, 2014 09:59 PM
n9lhm
19
Aug 14, 2006 10:55 PM
1969FordF250
Electrical Systems/Wiring
Apr 9, 2004 03:18 PM
94Explorer
Nov 12, 2003 08:35 AM
