Y Block Heat Riser Question
Old Mar 1, 2015 | 06:43 AM
raytasch's Avatar
raytasch
Believe Nothing
Originally Posted by Tedster9
Does anybody sell just the bi-metallic spring?
Do we know if it is actually a bi-metallic spring? The valve on my 56 is kicked open by the exhaust flow as the engine speed increases. I've owned many vehicles over the years and thought they opened by pressure. I don't know????
Old Mar 1, 2015 | 07:40 AM
Tedster9's Avatar
Tedster9
Well that's a good question I guess. The manual describes the heat riser as "thermostatically" controlled, so it would seem to be the case. It should also open at least momentarily while engine is cold, when throttle is winged. That's the pressure part of it. But, be fully open when engine is warmed up - at idle say? That would only happen if the spring was heat controlled as well.
In any case, I need a new one. edit: NumberDummy as usual has answered this before. Ford apparently never sold the spring separately from the exhaust control valve. It looks like other valves use a similar spring and could be made to work.
Old Nov 16, 2015 | 02:20 AM
Tedster9's Avatar
Tedster9
SO .. Question. Now that I have Rams Horn dual exhaust, should the heat riser ports on either side of the intake manifold be blocked off?
I never gave this very much thought. Didn't think it mattered - but tonite I was reading on the H.A.M.B. that doing so makes for a louder exhaust. And this setup is pretty quiet, can't figure out why.
texinwa
6.2L V8
Feb 6, 2018 04:45 PM
Kionga
Jun 16, 2016 02:01 PM
66fordf100
Nov 26, 2007 05:45 PM
evin
May 5, 2004 08:15 PM
gbickford
Apr 18, 2004 06:17 PM
