Obsolete and Interchangable
I wanted to talk about interchangeable and obsolete parts. Specifically my new 78 f150 custom. 4wheel drive, 300 and 4 speed. Nothing special, but im excited about it. Ill post a picture later.
Something that always bugs me are spliced and hanging wires. I don't mind accessories, but I cant stand hanging, spliced, cut, wrong wires. That is a big problem with mine. I wanted to get a new wiring harness. I have found some catalogs that carry OEM wiring harnesses for Chevy, but I CANNOT find anything for a Ford. I am very intimidated by aftermarket kits, but I think that's what I am headed with. Anyone have ideas? Im slightly worried that ill start find more parts that are simply not produced anymore.
V/R
Hawkins
Our K-40F is a custom wiring kit designed especially for 1960-and-newer Ford applications using FoMoCo switches and accessories. Our kits utilize the time-saving and easy-to-follow "point-to-point" system in which wires are run from the fuse panel directly to their marked destinations. For further simplicity, all wires are color-coded and labeled along their length, and, for safety, are a high-temperature "cross-link" type. In most cases, the correct electrical connectors are pre-installed on the harness to prevent errors and to speed installation.
Centech's tiny (3.5" x 6.0") PBP-1B fuse panel uses lugless connectors to eliminate unreliable ring terminals. Power is readily available from the panel for pre-wired after-market A/C systems and additional electrical needs such as power windows and stereos.
Instructions are supplied for the Ford Dura-Spark ignition system; however, the Davis Unified Ignition HEI distributor is highly recommended for ease of wiring and great performance for Ford engines.
