Loaner Tool Thread
Old Feb 25, 2015 | 11:18 PM
The Brad's Avatar
The Brad
Loaner Tool Thread
Hey all,
I figured this might be a helpful thread, like the map of members with AE. Anybody willing to list what 7.3 specific tools you have that you'd be willing to loan or rent to another? I was thinking something along the lines of a PayPal deposit plus 2 way shipping and an agreed return date.
I have a Rotunda valve spring compressor. It works much better than the universal compressors on the rear of the heads. Hopefully in a couple of weeks, I'll have a compression tester made up.
What do yall think?
Old Feb 26, 2015 | 07:41 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Sounds like a good idea Brad!
Old Mar 2, 2015 | 02:23 PM
Dan V's Avatar
Dan V
Originally Posted by The Brad
Hey all,
What do yall think?
Brad...will the spring compressor work to change valve guide seals while the head is on the engine...in frame?
Old Mar 2, 2015 | 04:20 PM
The Brad's Avatar
The Brad
Yes. Once you pull the rocker arm, the compressor threads into one of the holes in the head and hangs over the valve. You can put a ratchet on it to compress the spring and remove the retainers, then loosen the compressor and it swings out of the way. It works great on the rear of the heads, under the cowling.
Old Mar 2, 2015 | 06:00 PM
Dan V's Avatar
Dan V
Yes. Once you pull the rocker arm, the compressor threads into one of the holes in the head and hangs over the valve. You can put a ratchet von it to compress the spring and remove the retainers, then loosen the compressor and it swings out of the way. It works great on the rear of the heads, under the cowling.
I'll be contacting you about it.
Old Mar 2, 2015 | 06:50 PM
The Brad's Avatar
The Brad
Here's a link to it.
Valve Spring Compressor 303-483 T94T-6513-AH
Old Mar 26, 2015 | 11:00 PM
The Brad's Avatar
The Brad
Well, this thread didn't go where I expected it to. Anyway, thanks to my latest trials and tribulations, my rental tool fleet has grown to include:
0-60psi liquid filled gauge on a #4 orb to put on the HPOP reservoir, to check LPOP performance.
0-3000psi liquid filled gauge on a #6 orb and #6 orb plug to dead head a suspect HPOP.
Old Apr 9, 2020 | 06:47 PM
Kevin Henne's Avatar
Kevin Henne
Hey all,
What do yall think?
Hi Brad, any chance I can rent the valve spring tool from you?
Kevin
Old Apr 9, 2020 | 09:02 PM
FordTruckNoob's Avatar
FordTruckNoob
Kevin
His last post on this thread was from 2015. I have tagged @The Brad for you so the forum software notifies him.
Old Apr 9, 2020 | 09:14 PM
The Brad's Avatar
The Brad
Kevin
Send me a Pm with your contact info.
Old Apr 9, 2020 | 10:45 PM
countrycar's Avatar
countrycar
I have the ST-169 Crankshaft Rear Oil Seal & Wear Ring Installer 303-S485 T94T-6701-AH Alt from freedom racing if anyone needs to borrow this tool.
https://www.freedomracing.com/303-s4...waAl7qEALw_wcB
Old Apr 10, 2020 | 05:13 AM
Kevin Henne
I'm new to the site so I dont have access to that feature yet.
Last edited by Kevin Henne; Apr 10, 2020 at 12:39 PM. Reason: Correcting typo with email
Old Apr 10, 2020 | 01:04 PM
The Brad's Avatar
The Brad
Email on the way...
Old Apr 10, 2020 | 01:21 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Reps sent The Brad, thank you for helping out every chance you get.
Old Apr 17, 2020 | 09:57 PM
Reddogarchery's Avatar
Reddogarchery
Spring compressor tool
hey the Brad could you email me the dimensions of that tool so I can make one... reddogarchery1@msn.com
