tune up spec
Old Jul 23, 2003 | 01:10 PM
enrightrobert's Avatar
enrightrobert
Question tune up spec
I need timing setting for 1972 F-250 360 cui: Idle speed, dwell setting
Old Jul 23, 2003 | 05:33 PM
71_4x4_390's Avatar
71_4x4_390
tune up spec
go to the
1967 - 1972 Ford trucks
section of the forum for all this stuff, it's in the first post...
Old Jul 24, 2003 | 10:18 AM
William's Avatar
William
tune up spec
Install a Pertronix Ignitor and forget points and dwell. Gap the plugs at 60, use a hotter coil, set timing initial at 15 and back off 2 degrees at a time until it quits pinging on 87 octane or leave it at 15 and pay for high test. Idle is up to you, I like 800, 650 is good for a standard trans. One more thing, JEGS sells a flat cap, rotor and adapter that will work on your distributor. Add a set of 8mm plug wires and you are in business. I have run this setup for over 35K miles without any issues. You could switch to a dura spark as well. Whatever you do lose the points. Ain't worth the hassel.
Old Jul 26, 2003 | 06:44 PM
superswamper's Avatar
superswamper
tune up spec
whats the advantage of a flat cap and rotor?
