Bog down ?
Old Jul 23, 2003 | 01:03 PM
71ranchero500's Avatar
71ranchero500
Bog down ?
I have a rebuilt holly 2b carb on my 302 that isn't more than 2 months old for the past week the acceleration has been crapy when I give it gas. I put the carb on myself the gaskets are good and the fuel filter was changed the other day. i don't know if there really is such a thing as "bad gas" ? i use the 91 all the time but since i filled it up its been really bad. im waiting for the tank to run out of gas and see if its the problem can gas cause this or should i take it back to the store i got it from its still under warranty with them for another month or so and it has a manufacture warranty for about a year i think.
so my question is
Crapy rebuilt or bad gas?
Old Jul 24, 2003 | 10:48 AM
Kemicalburns's Avatar
Kemicalburns
Bog down ?
i think its time for a new intake and carb. Whats your timming set at, what do your plugs look like? does it feel like its loading up when you first start moving then clears once the rpms pickup?
Old Jul 24, 2003 | 04:18 PM
71ranchero500
Bog down ?
I will be getting aluminum intake and a 4b carb in the next month or so
I just spent 175 on this one so i want it to last tell then
I hear good things about road demon Jr 625 and it’s at a good price on eBay and i think im getting a new intake from
http://www.jcwhitney.com/product.jht...405519&BQ=jcw2
This one
My plugs are good i just changed them
And it clears up when im at higher rpms
I don’t have the prob when im going on the freeway
Just if i have to "punch it" from a light or excel fast
I have let the gas run out and put new gas in and it seems to have solved the prob but i still need to upgrade and that’s what my plan is
I also had to change one bad spark plug wire and im going to get a new electronic distributor also
And it seems to misfire a bit but doesn’t affect it to much and i can’t find any vacuum leak
Anything else you can tell me would be appreciated
Thanks
Old Jul 24, 2003 | 04:30 PM
Kemicalburns
Bog down ?
the misfire could be from a plug wire arching to somthing else like the header flange or another wire. how many miles are on this motor? just asking because maybe your timing chain is needing to be replaced
later
Old Jul 24, 2003 | 04:36 PM
71ranchero500
Bog down ?
It cant have to much more than 5000 mi or so
ive replaced everything but the distributor /coil and module
when the engine was rebuilt
Old Jul 24, 2003 | 04:39 PM
Kemicalburns
Bog down ?
are you running an msd box at all?
Old Jul 24, 2003 | 04:41 PM
71ranchero500
Bog down ?
No its some kind of factory setup its been on the truck since i got it not sure what kind off hand
Old Jul 24, 2003 | 04:43 PM
Kemicalburns
Bog down ?
well it sounds like you have a good idea on whats left to replace. any one of those three things could cause your miss if there not working properly.
late
Old Jul 24, 2003 | 04:46 PM
71ranchero500
Bog down ?
Thanks for your help
I dont know that much about my truck just the basic, so advice from anyone is alot of help for me
i just hope when i replace those things it runs like new
Thanks
