Doing an egr delete
Old 02-23-2015, 10:26 PM
imjwm's Avatar
imjwm
imjwm is offline
Doing an egr delete
What for cost am I looking at to do an egr delete? What is a recommended tuner for the 6.0? How much time would it take? I'm sorta new to working with the 6.0. Thanks for your help!
Old 02-24-2015, 10:11 AM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
Depends on are you doing an egr cooler delete or the EGR valve and why.
Do you have a current problem or is this just prevention? A bullet proof procedure.
What year? All factor in to the time required and cost.
Old 02-24-2015, 11:38 AM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
I am working on getting all the stuff up right now myself. I am changing dummy plugs, standpipes, stc fitting, full flush and refill with elc, oil change, fuel filter change, transmission pan and filter, trans refill, egr delete with new uppipe and a new y pipe, new belt and hoses. All this together I am budgeted total for ~1000 give or take but that number includes all ancillaries--gaskets, fluids, tools, etc. I will be taking a week off work to do the job. Oh--I'm not including a tuner in my numbers right now either. If you're just doing a egr delete (depending what brand) the min. you have is the delete kit and coolant to top off with and a tuner (I assume you will be getting one) I'm using the IPR delete and uppipe and that will all the gaskets, turbo mount kit, etc is around half of my budget. Hope this helps.
Old 02-25-2015, 03:01 PM
imjwm's Avatar
imjwm
imjwm is offline
I'm wanting to do an egr cooler delete and a tuner. Do you need a tuner to do a delete?
Old 02-25-2015, 03:21 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Some trucks depending on pcm flash will set the CEL when you do a delete. Far as I know that's the only reason for the tuner is so you can turn off the EGR and not set the CEL.
I don't plan on getting a tuner too soon after I finish mine so will probably be staring at the CEL for a while lol.
Old 02-25-2015, 03:24 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
it depends on the software version in your truck. Generally earlier model trucks won't turn on the Check Engine Light and later models will. If the light on the dash doesn't bother you, it will not be a problem for you as far as mounting or how it works. The tuner will tell the pcm to ignore the EGR, and the light will stay off.
BigDaniel
6.4L Power Stroke Diesel
05-29-2018 07:45 PM
Restlesswildman
10-21-2013 01:03 PM
olfordsnstone
05-27-2013 02:04 PM
MoyockPowerstroke
12-29-2009 08:46 PM
wyoguy
06-20-2006 10:08 PM
Quick Reply: Doing an egr delete
