Tire Chains
Old Feb 25, 2015 | 12:31 AM
capt caper's Avatar
capt caper
Darren I have the same chains. I am looking for a easy way to put them on. Being inexpierenced at them how do you do it?
Originally Posted by darren32
The chains you choose will depend on the intended use.
Where I go cable chains will not cut it. I have gotten stuck with heavy link chains.
I use chains often and have had no issues with ABS.
I think the issue with the 20" wheels is nothing more than a concern with the chains scratching the wheels ......
I would get whatever will work for your application.
Old Feb 25, 2015 | 07:47 AM
darren32's Avatar
darren32
Well ... these are a bit different than any I have had in the past. Previous chains I had were more "universal" and easier to get on. Lay them out, drive on them and hook 'em up. These custom fit ones are a LOT tighter. The drive on method does not work. The first time I went to put them on I thought they were too small so I called them and said they sent the wrong size. They were right ... just very tight (which in the end is good).
You need to lay them on from the top of the tire with the cams to the outside obviously. They say the U links that connect the bars to the side chains should have the sharp side up (I guess cuz it could damage the tire) but I didn't find it made a difference. You need to make sure they are centered and square 100%. Pull all the cross chains until they are level and square. Then connect the back hook. Now when you go to put the cam together it may seem impossible LOL. Start at the top middle and pull the cross chains toward you making sure they are not caught on any tire lugs. Work your way down and to the sides cross chain by cross chain. What you trying to do is tighten up the back chain ring and make sure none of the cross bars are binding on lugs. Once you get down to the cam you should be able to get it engaged.
It sure would be nice (for the money) if they gave you a tool to crank up the cam. I found that the jaw from a bearing puller works well to crank the cam.
If you want I can take some pics next time I put them on. The first time was a real pain in the azz ... probably took me a hour tying to figure out how to do it. But it gets much easier. Now I can get all 4 on in about 10 min.
Thanks
norcal_flyfisherman
2015 - 2020 F150
Feb 7, 2021 07:39 PM
dennis48755
2015 + Expedition & Navigator
Jan 28, 2015 10:05 AM
BigMightySam5600
2009 - 2014 F150
Dec 16, 2013 09:36 AM
lanedecamp
6.7L Power Stroke Diesel
Oct 19, 2012 08:32 PM
asok
Nov 17, 2010 10:42 PM
