Sponsored by: Real Truck
Heater problems
Old Feb 23, 2015 | 04:36 PM
oreo31's Avatar
oreo31
Heater problems
I can't get much heat out of my 2006 f-250 6.0. I just changed my heater core because I thought there may have been some restriction in it, but that still didn't help. Any suggestions would be appreciated. Thanks
Old Feb 23, 2015 | 04:51 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Do you have a gauge to read actual engine coolant temp (ECT) other than the idiot stick on the dash? My heater doesn't work nearly as well in the 170s compared to when it's up to temp at 190*f+, and t-stats are a common weakness on the 6.0L.
Gauge setup information:
https://www.ford-trucks.com/forums/1...eral-info.html
Old Feb 23, 2015 | 05:16 PM
oreo31's Avatar
oreo31
I sure don't. It won't heat hardly at all at an idle, but it will heat up a little when you take off and stay in the throttle
Old Feb 23, 2015 | 05:29 PM
texastech_diesel
Token Redneck
Gut reaction w/o data is the t-stat is failing. You should join us in the 6.0L engine forum, we have a couple threads going on thermostats right now, and can help you out with the engine in general.
https://www.ford-trucks.com/forums/1...hermostat.html
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
boybowser
Apr 16, 2018 02:14 PM
brad1985
1997 - 2003 F150
18
Nov 13, 2010 06:04 PM
brentleedragon
Feb 2, 2008 01:13 AM
CherryColaholic
Bronco II
Jan 27, 2005 05:42 PM
maco24
Mar 14, 2003 03:51 AM
