Bronco II Ford Bronco II
heater sucks.
Old Jan 26, 2005 | 01:32 PM
CherryColaholic's Avatar
CherryColaholic
heater sucks.
Im not very knowledgeable about the whole cooling/heating system so this may be a no brainer for you guys. Here goes. My heater takes freakin forever to heat up. Then if im at idle at a light, it goes cool again. The only time i can actually get it hot is if im driving down the highway for about 15 minutes. Now last winter it would heat up pretty quick, and stay hot all the time. Ive replaced a lot of stuff since then, including water pump and the thermostat. Both work fine as far as i can tell, no leaks or anything. The temp gauge shows the temp go up and stay in the middle after driving for a few minutes. what am i missing?
Old Jan 26, 2005 | 02:15 PM
bronco2man's Avatar
bronco2man
heater core
Old Jan 26, 2005 | 07:58 PM
Ken00's Avatar
Ken00
I would suspect a clogged heater core too.
Old Jan 26, 2005 | 09:26 PM
CherryColaholic
Heater core huh. So what exactly is it clogged with and how do i fix it?
Old Jan 26, 2005 | 10:19 PM
bronco2man's Avatar
bronco2man
Thumbs up
you night be able to get unplugged by having it back flushed and then refilled, if that doesnt work you have to replace it
Old Jan 27, 2005 | 05:42 PM
steve381's Avatar
steve381
its an easy and cheap project on these trucks
