6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Exhaust brake problems
Old Feb 23, 2015 | 03:28 PM
redz284u's Avatar
redz284u
For the 3rd time now, going about 55-60mph, down hill, my exhaust brake kicks in extremely aggressive. Shoots my rpms up to 4k, and my coolant leaks all over the place. I loose about half a gallon of it each time. It's really begining to worry me. Any thoughts?
Towing in tow/haul mode, switch it out immediately, but it's too late. Coolant loss.
Any reason this would be happening? How to diagnose or fix?
5th'er dials in at 18k lbs.
Old Feb 23, 2015 | 03:50 PM
mohle's Avatar
mohle
Unles you have added an aftermarket one, you don't really have an exhaust brake on your truck. The transmission is merely gearing down. If you are losing coolant during this, I would believe your heads are lifting and/or your head gaskets are toast.
Old Feb 23, 2015 | 03:59 PM
redz284u's Avatar
redz284u
Please don't say "H... G....."
If it was the head gaskets, wouldn't I see white smoke. Specially under such heavy load?
Is there a way to verify it is or it's not the head gaskets?
Old Feb 23, 2015 | 05:53 PM
senix's Avatar
senix
Change the degas bottle cap first. Sand (lightly) the opening of the degas bottle before putting a new cap on it.
See if that cures it.
Old Feb 23, 2015 | 05:57 PM
redz284u's Avatar
redz284u
I'm on my second cap in 6 months. First one I though maybe defective. But now second, can't be.......so I decided to post here.....
Old Feb 24, 2015 | 12:33 AM
mohle's Avatar
mohle
Sorry, but it sounds like you have exhaust gases getting into your coolant passages. Really the only way this can happen in such volume is if your heads are lifting or you have a gasket blown. Either way, you will have to replace the head gasket. I would try the cap, but the chance of that causing it are pretty slim given the description you are giving. High RPM shouldn't really increase the pressure in the cooling system that much. Have you checked if you have any cross contamination between oil and coolant?
Old Feb 24, 2015 | 12:47 AM
mohle's Avatar
mohle
You would only be getting smoke if the coolant got into the combustion chamber. Sounds to me like you have combustion gas going into the coolant. You may also want to inspect the EGR coolers.
Old Feb 24, 2015 | 04:58 AM
senix's Avatar
senix
hg issue I am afraid. Good news is it sounds like you can nurse it along before you have to do the repair.
Old Feb 24, 2015 | 08:28 AM
fatboytx's Avatar
fatboytx
To test EGR coolers ... on a cold engine pull the EBP sensor near horizontal cooler and then pressurize the cooling system. Wait 15 minutes or so to see if any coolant appears.
Old Feb 24, 2015 | 11:42 AM
redz284u's Avatar
redz284u
Anybody have any feedback regarding the cause of the problem? Why will it down shift so aggressively and put my rpms in the 4k range?
Old Feb 24, 2015 | 07:45 PM
mohle's Avatar
mohle
Not the expert on this, but I would assume that because the combustion gases are escaping, the engine can rev more freely. Furthermore, the electronics are probably telling the engine to go for even higher RPM as it's not seeing the deceleration that it is anticipating.
Old Feb 28, 2015 | 05:59 PM
mohle's Avatar
mohle
Redz284u, what did you end up finding?
Old Feb 28, 2015 | 06:08 PM
redz284u's Avatar
redz284u
Nothing so far. Have to take it in to see what's the deal. I stopped driving it until I have some cash for the head gasket in case it does end up being that.
Old Mar 1, 2015 | 02:47 AM
mohle's Avatar
mohle
It is too bad these things are so expensive to fix.
4.9inline6
Oct 4, 2011 12:24 AM
JNKDad
Mar 25, 2010 11:01 PM
GJSPCLT
1997 - 2003 F150
Dec 10, 2009 09:41 PM
renchr56
Nov 29, 2005 03:00 PM
TdiRAcing
26
Sep 15, 2004 09:00 AM
