Coolant from Exhaust
Old Oct 3, 2011 | 09:32 AM
4.9inline6's Avatar
4.9inline6
Question Coolant from Exhaust
Hello all,
96 F250 351W ~ 178,000 miles
My step dad was driving and said he noticed he had some smoke coming from the exhaust. Shortly after, it started running hot.
The next day, I went out and started it up. MASSIVE amounts of coolant are shooting out the exhaust - 2 seconds with your hand against the tail pipe results in a wet hand. I could probably put a collector on the tail pipe and route the coolant back to the radiator overflow... But then again, I don't want to look like an idiot! Haha.
I haven't had a chance to do a compression test but I'm assuming the head gasket is shot. I think I'm going to tackle changing out the head gaskets this weekend, assuming my diagnosis is correct. Engine itself seems to be running quite amazingly. Thoughts?
Should I do anything else while I'm in there? I'd love to pull the engine and rebuild it but I would really like to get this thing back on the road by the end of next weekend.
Thanks in advance,
Chris
Old Oct 3, 2011 | 09:37 AM
TheWhiteBeast's Avatar
TheWhiteBeast
Head gasket. Make sure you use new head bolt hardware. ARP preferably.
Old Oct 3, 2011 | 09:44 AM
4.9inline6's Avatar
4.9inline6
Yeah I panned on using new bolts. Thanks for the suggestion (ARP). I definitely would not have know that.
Old Oct 3, 2011 | 10:19 AM
TheWhiteBeast
They are used for pretty much any high performance build and I, and many other people swear by them.
Old Oct 3, 2011 | 11:33 AM
Chris72's Avatar
Chris72
head gasket at minimum. Could be as bad as a cracked head or cracked block, but most likely just a head gasket.
Old Oct 3, 2011 | 12:15 PM
4.9inline6's Avatar
4.9inline6
I'm hoping just head gasket, but then again who wouldn't. I feel/hope strongly that this is the case as it runs great still, somehow. Idle and rev sounds strong, no misses, stutters, etc. If I find there are more issues than just the head gasket, I am thinking about pulling the whole thing and swapping or rebuilding. I'd hate to slap new heads on and find the bottom end blows out 5k miles down the road.
Old Oct 3, 2011 | 01:28 PM
Encho's Avatar
Encho
The Southernmost Mod
If you're sure the gasket has failed why you keep running the engine? you will damage the engine beyond repair (actually will require a rebuild).
Old Oct 3, 2011 | 01:38 PM
4.9inline6's Avatar
4.9inline6
I started it to diagnosis the problem before I knew what was wrong with it. I later started it once more to show my brother/talk it over with him. It is not being driven and wasn't ran for an extended period of time besides my initial diagnosis , which was done while parked. I guess my previous post was a bit misleading, possibly suggesting that it was still being driven. If someone were crazy enough to drive it, it wouldn't get far as it's spewing coolant entirely too quickly.
Side note, has anyone done a write-up on this process? If not, I'm thinking about taking pictures of the process and posting it all on here for future do-it-yourself people.
Old Oct 3, 2011 | 08:02 PM
Dylan208's Avatar
Dylan208
Please do!! i got some head gaskets i need to replace too.
Old Oct 3, 2011 | 08:09 PM
jroehl's Avatar
jroehl
Make sure you get those heads magnafluxed when you pull them. It would suck to put it back together only to have cracked heads because you got them too hot.
Jason
Old Oct 3, 2011 | 08:26 PM
White 97 xlt's Avatar
White 97 xlt
Jason
VERY good advice!!!!!!!
Old Oct 4, 2011 | 12:24 AM
Encho's Avatar
Encho
What does "Magnafluxing" consist of? is it just an ultra-sound test?.
Dale Cooper
Jun 6, 2014 11:16 AM
Science1974
May 25, 2013 05:24 PM
fallguy
Modular V10 (6.8l)
13
Jul 7, 2011 05:19 PM
GJSPCLT
1997 - 2003 F150
Dec 10, 2009 09:41 PM
K man
Feb 6, 2007 09:29 PM
