No start
Old Feb 23, 2015 | 03:25 PM
Griffin9's Avatar
Griffin9
No start
Yesterday the truck fired up fine, i get out from being a work for a while, the truck doesn't fire, I tried starting fluid, didnt work. I go out this morning and now the truck doesn't even have any *** to start, im not sure how to explain it but it doesn't feel like theres any compression to start, its more of like a whine, its like it lost all power to start.
Old Feb 23, 2015 | 03:47 PM
pilgrimbizket's Avatar
pilgrimbizket
Is it turning over?
Do you have a WTS?
Old Feb 23, 2015 | 03:56 PM
Griffin9's Avatar
Griffin9
Yeah its starting, it just doesnt have any *** to start anymore, before it wanted to start now it just gave up
Old Feb 23, 2015 | 04:53 PM
madpogue's Avatar
madpogue
Um, those are completely contradictory statements? So is it starting or isn't it?
If it isn't starting, is it CRANKING?
If it's cranking, do you see the tach moving?
And still no answer to question 2 in post 2 - do you get a WTS light?
Old Feb 23, 2015 | 05:56 PM
Griffin9's Avatar
Griffin9
Um, It's CRANKING, yes. Yes there is a Wait to Start light, like I said, last night the truck was cranking and acting like it wanting to start, a few times it would stay running for a few second in the cranking position. Today, the truck is cranking and turning over just fine but it doesn't have any *** to start itself, It's more like a weak crank if that makes sense, I'm not sure how to explain. The batteries are good.
Old Feb 23, 2015 | 06:08 PM
madpogue's Avatar
madpogue
Is the tach moving when you crank it?
Do you see any smoke from the tailpipe?
Old Feb 23, 2015 | 06:10 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
What's the temperature there. It sounds to me like you have a major glow plug problem AND the batteries have been drained from excessive cranking. The whine is a bit curious. That could be the starter not "engaging" ( someone remind me what the doodad that engages the starter to the flywheel is).
Old Feb 23, 2015 | 06:17 PM
Griffin9's Avatar
Griffin9
Yes the tach is moving and yes white smoke is coming from the tailpipe
Old Feb 23, 2015 | 06:18 PM
Griffin9's Avatar
Griffin9
That's what I'm thinking, around 15 degrees, I needed to replace the glow plugs prior to this but it hasn't been an issue, last night the truck was sounding good while i was cranking it, today its very weak and tired
Old Feb 23, 2015 | 06:20 PM
ProjectDually's Avatar
ProjectDually
I believe what you are looking for is the Bendix drive.
Starter could be burnt out, along with the GP problems.
Old Feb 23, 2015 | 06:21 PM
madpogue's Avatar
madpogue
That would be the starter solenoid activating the bendix spring which engages the starter gear to the flywheel ring gear. But the OP says that the engine is turning over.
Old Feb 23, 2015 | 06:26 PM
ProjectDually
Do you remember the last GP change? Which GP's were used? Valve covers, were they OE or were they dorman parts store UVHC's?
Old Feb 23, 2015 | 06:28 PM
Griffin9's Avatar
Griffin9
I'm not exactly sure, It's been a while. Problem I'm having is that last night the truck had a good hard crank to it, now today it's all worn out and sounds very weak, I wasn't sure if i changed the glow plugs, if it would fix it.
Old Feb 23, 2015 | 06:32 PM
ProjectDually
Did you try plugging the truck in? Batteries were freshly charged this morning?
Old Feb 23, 2015 | 06:33 PM
Griffin9's Avatar
Griffin9
Yeah I had it plugged in for a while and the batteries are charged, It has a fast cranking to it but it doesn't shake and rumble like it used to when i started it, now its just nothing, cranking thats it. Kinda hard to explain
