ts 6 position chip problem
Old Feb 23, 2015 | 09:57 AM
stetsonihnen's Avatar
stetsonihnen
I bought a ts 6 position chip off ebay for my 2000 7.3 powerstroke manual. When i plug it in the high idle lopes. And on very other setting there no power. Going through any of the settings changes nothing. When i step on it it does not accelerate at all. What could be the problem?
Old Feb 23, 2015 | 10:00 AM
stetsonihnen
And when i am sitting at a stand still and step on it. It just pours smoke.
Old Feb 23, 2015 | 10:02 AM
Robert6401's Avatar
Robert6401
Did you confirm that the chip is for the correct PCM code? Who did you purchase the chip from? Whose tunes are on it?
Old Feb 23, 2015 | 10:14 AM
stetsonihnen
Yes they do match up. They are the stock tunes from ts
Old Feb 23, 2015 | 10:28 AM
Robert6401's Avatar
Robert6401
Are you certain all of the contacts on the PCM are clean? But not damaged? I know this is very basic, but we have to start with the simplest possibilities. I know when I first installed my chip I swore the contacts on the PCM had all of the film removed, but I had to go back and do a little more. Just don't go so far that they are bronze. I used a combination of a toothpick and a very light rubbing with a scotch pad.
Old Feb 23, 2015 | 10:31 AM
stetsonihnen
now when i put the chip in it will not let my truck start at all. What is going on?
Old Feb 23, 2015 | 10:39 AM
Robert6401's Avatar
Robert6401
It really sounds like a poor connection between the chip and the pcm.
Old Feb 23, 2015 | 10:40 AM
Robert6401's Avatar
Robert6401
If you pull the chip, does the truck run normally?
stetsonihnen
I can see copper tho
Old Feb 23, 2015 | 10:43 AM
stetsonihnen
yes it runs fine then
Robert6401's Avatar
Robert6401
Here is a link from DP Tuner showing proper installation. There is a good image of how the contacts should look after cleaning a few pages into the document. There is kind of a fine line between good and clean and taking off too much.
http://www.dp-tuner.com/skin/fronten...stallation.pdf
Old Feb 23, 2015 | 10:45 AM
Robert6401's Avatar
Robert6401
Then the good news is you haven't damaged the actual PCM. If your contacts have been rubbed down too far, then you may have to have them re-tinned, typically by an electrician or someone with better soldering skills than I have.
Old Feb 23, 2015 | 10:52 AM
stetsonihnen
I installed it properly.
Old Feb 23, 2015 | 10:53 AM
dylinbrock's Avatar
dylinbrock
the chip is the problem
Old Feb 23, 2015 | 11:05 AM
Robert6401's Avatar
Robert6401
Yeah, that's the only possibility. If the truck runs fine without it, then it's the chip. Either a bad connection or bad tunes.
