Questions for Fifth Wheel Newbe
Hello
I have a 2011 F250 with 20" wheels. This came from the factory set up this way. I have not lifted it or modified it in any way.
I want to buy a fifth wheel Flagstaff 8528IKWS and am worried that the bed rail to trailer clearance is not going to reach the recommended 6 to 8 inches.
Per the dealer, the axles on the Flagstaff can not be flipped and must have a lift kit welded on to them and that I may have to replace the existing entrance steps.
Dealer also says that the underbed rails for the hitch causes the pucks to extend 3/8" to 1 inch above the top of the floor ribs making the need to place lumber and plywood into the bed to get a flat floor.
Questions
Does anybody own a 8528IKWS and F250 with 20" wheels?
What did you do to achieve the recommended bed rail to trailer clearance?
Is there a fifth wheel hitch out there that gives true flat bed floor without the need to use lumber and plywood?
What is better, under bed rails or above bed rails for the hitch?
Thanks
Steve
Questions
Thanks
Steve
Does the dealer have one on the lot? Back under it and see for yourself. Add an inch or two for truck squat.
I'd be real curious as to why the axles can't be flipped. And you don't really HAVE to replace your fold out steps, you will just have a little higher first step. My previous 5th wheel had the axles flipped and the original steps. Not really a big deal.
Not sure, but it is generally the case the modifications of anything on an RV void the warranty. Has anyone had a dealer who will flip the axles on a new unit? Unless the manufacturer approves the mod., the liability is so large most dealers and techs will not make the mods. I know I routinely refuse to do things with well known components until the warranty is done. The parts catalogs even have listing for the part you have to use before and after warranty. I would suggest calling the manufacturer and see what they say.
I agree regarding the steps. just put something at the last step to step off on. We use a step stool.
Steve
Steve
This is the most practical fix. The hitch needs to be mounted and adjusted to the hitch manufacturer instructions. The manufacturer will tell you what alignment and clearances should be maintained. I found the dealer never really read the manufacturer manual when they installed mine (a manly thing). They assumed 5 inches was enough bed clearance when the company recommended 6 inches minimum and 8 - 10 inches for off road use. I ended up with a scar on my tonneau cover as a result. Could have been worse.
18" wheels or 20" wheels will not make a difference. The tire diameters are most likely the same.
Assuming that he has the oem size tire you would be correct. I don't understand why he would have a clearance issue if the truck suspension is stock. That style fifth wheel is towed by thousands of F 250s. The dealer should be able to get this right.
http://www.forestriverforums.com/forums/f33/towing-the-flagstaff-8528ikws-36362.html
The pucks on the Ford / Reese Elite system only stick up a minimal amount over the bed ribs. Not enough to be an issue. I know Senix has pictures of his floating around. I don't have any pics of mine, but I'd take the Reese Elite over rails any day of the week.
I solved the issue with a dually....................sits about 4" lower in the back than SRW. Rail clearance and a level trailer were part of the reasoning for that decision. The SRW's are really tall.
4x4's fit just fine. I have one and most of the ones that I've seen hauling that style trailer do not need any modification.
Maybe your hitch and frames/ rails weigh more than mine but it does not lower the the truck and if it does it can't be by much at all that can be seen with a visual measurement with out tape ruler.
