I do apologize, this is my first rodeo here and I'm working on learning. In post #7 I describe my situation a bit better.
Ah, sorry, somehow I missed that. Not trying to give you a hard time, just was imagining you had the pistons, etc. out of it. Don't worry, we all learn sometime!
With it still being outside the truck, if you really want to find out whether it's a 360 or 390, you could pull the oil pan and measure the stroke (the distance between the top and bottom of piston travel - it's also twice the distance from the centerline of the connecting rod bearing to the centerline of the crankshaft main bearing). If the stroke is 3.5", it's a 360; if it's 3.78", it's a 390 (both of those two would have a 4.05" bore).
I'm not sure if it matters for the header question, which it looks like has already been answered, but if you just want to know for your peace of mind, that's probably the surest way to find out. If you had the heads off, I'd measure from the top, but I wouldn't pull the heads just to measure: pulling the oil pan is easier.
Thanks for the reference! Great thing about it is it is a temp motor. Bought an FE so that I could at least get my dad's old truck running before I put the new engine in it. He just passed the title onto me as a birthday present and I was looking for a 390 for a temp just so it would be like it was when he ran me around in it as a kid. But since I'm not sure, I was going to build a new block for it. But since it is still out, I'll pull the oil pan again and check it.
On an OHC engine, with the spark plug up top (and if he were sure of the bore), that would've been my first recommendation. I don't have direct experience with the FE in particular to know whether it's possible to get a dowel vertical enough to make a good measurement with their spark plug geometry or not. If it is, then yeah, that's definitely easier. Thanks!
The bore is the same on the 360/390. Stroke is the only difference.
The FE uses a rather fat spark plug. While the dowel won't be perfectly straight up and down, its close enough to determine whether it's one engine or the other. Just make sure the piston comes all the way up and then all the way down when measuring.
To the OP... And all others concerned... This information is all available on this site and many others. All it takes is a simple search to find just about anything you need to know on these engines.
