6.2L V8 Discuss the 6.2L V8
Torq shift
Old Feb 21, 2015 | 11:14 PM
brandon.edwards's Avatar
brandon.edwards
Torq shift
i had a little bit of a scare today. I plow with my 2015 f350 and plowed for 18 hours today. Turned the truck off once or twice. So I get home finally and my neighbor asked me to clear his driveway. So I get back in my truck
, start it back up and put it in drive, and the tranny goes straight to 5th gear. Never has done that before. So I went from park back to drive I heard a click and it went back to 5th and wouldn't come out. So I restarted the truck and it reset and was fine after that. Any ideas what could have been going on?
Old Feb 22, 2015 | 05:39 PM
clintbonnie's Avatar
clintbonnie
Just curious.. did you happen to check the trans temp during those 18 hours ? Might have over heated.. just guessing.. My old 99 superduty diesel trans would really heat up going thru town in 1st and 2nd gears..
Old Feb 22, 2015 | 05:58 PM
brandon.edwards
Yes sir. Being a previous 6.0 owner and plowing with that diesel, keeping an eye on temps is something i do very well and often
Old Feb 26, 2015 | 08:29 PM
radar_ridr's Avatar
radar_ridr
Computers crash occasionally. It's like "death and taxes". Especially after all the processing it had done through the day. The first thing we always do with any goofed-up PC is reboot it. That solves the problem about 3/4 of the time. The fact that restarting it got it working properly again sounds like one of those cases. But that leaves the "click" unexplained... unless the PCM triggered some servo that got stuck after a hard day's work, or one of the bazillion gadgets for the stability control. The manual indicates that some strange noises may emanate from that right after startup. I also seem to remember something about all the gear numbers blinking, or something like that, if it detects a serious problem.
You previously had a 6.0, and you plow snow... I bet you already checked the tranny fluid level...
A one-time malfunction is an anomaly. A second or third time would mean there's a problem. It would be interesting to check the PCM to see if any trouble codes were recorded.
I have to ask, otherwise, how does the 6.2L / TorqShift perform plowing snow?
kc2006
Apr 10, 2011 10:58 AM
IDMooseMan
Idaho Chapter
466
Jan 1, 2011 04:31 PM
ssharber
6.4L Power Stroke Diesel
Mar 2, 2009 07:55 PM
DieselCamper01
38
Feb 11, 2008 12:08 PM
Mr86GT
2004 - 2008 F150
24
Apr 14, 2007 12:42 AM
