Another Ranger No Start
Old Feb 21, 2015 | 10:56 PM
banditlee23's Avatar
banditlee23
Hi everyone, new here and I'm having a mind blowing experience with my 91 ranger 3.0. First a small list of parts I've replaced in the last 4 months.
Plugs, wires, cap, rotor, fuel pump, filter, fpr, alternator, water pump, coolent temp sensors, idler pulley, all 4 brakes, shocks, pilot bushings.
Here is my problem. I have spark, I have good, even within 2 pounds of 125 psi, compression, engine is getting fuel, plugs are all wet. And there is nothing blocking my intake. I've cleaned the IAC valve, and even added new plugs again. I have pulse at all injecters, and plenty of cranking power. Pulled the distributor apart and checked power there. Even cleaned it up on the inside of any surface rust on any metal parts. I am absolutely stumped. I have all 5 of the cruitial things a motor needs. Spark, air, fuel, compression, and the timing seems to be dead on. Ran fine up until I parked it 3 weeks ago. Has no codes whatsoever. Came out the other night and tried to start it up, wouldn't go. How does it go from running perfect to crap in 3 weeks? Any help is appreciated. Thanks.
Old Feb 22, 2015 | 07:46 AM
f5fordgirl's Avatar
f5fordgirl
What kind of fuel pressure do you have?
Old Feb 22, 2015 | 08:19 AM
banditlee23
Just had it at my local mechanic shop, he said it is at spec. 50psi. It shoots out of the valve and hits the hood lol poor description with out a gauge, but checking it before is what led me to change the pump. Barely trickled out turning the key on before
banditlee23
And it ran great after the pump was put in.
Old Feb 23, 2015 | 01:52 PM
Rockledge's Avatar
Rockledge
You said the plugs are wet with fuel which may indicate no spark in the cylinders...? Did you actually check for spark out at the spark plugs?
Old Feb 23, 2015 | 02:11 PM
banditlee23
There is nice blue spark at the end of all 6 plugs.
Old Mar 3, 2015 | 01:19 AM
g_k50's Avatar
g_k50
Try to start with Ether in the airbox.
if it try's to start it's a fuel problem.
If not then I would double check the timing.
Old Mar 10, 2015 | 01:49 AM
Askye's Avatar
Askye
+1 for timing, I would double check your ignition timing.
Old Mar 10, 2015 | 01:57 AM
KF4EYR's Avatar
KF4EYR
does it have a security system? been seeing here lately no start having to do with the security system acting up...............
Old Mar 10, 2015 | 02:50 AM
Askye's Avatar
Askye
This is another good thing to check for. Many aftermarket systems will have certain cut offs to prevent the Vehicle from starting. Its usually a starter interrupt but it doesn't hurt to check.
pistol22cal
Jun 9, 2017 02:50 PM
Jerryoke
Jun 22, 2014 09:51 PM
elranger
Apr 29, 2012 08:49 PM
simmonds1970
15
Feb 24, 2012 10:44 PM
davidsheets
3.0L V6
Jun 20, 2011 01:05 PM
