1978 - 1996 Big Bronco
78 Trailer Special Project
Old Mar 19, 2015 | 11:36 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
Very well done! I love seeing things like this, then I can impress others when I do it! That is until I break down and tell them I saw it on FTE!
Originally Posted by HuntinBronc
I wanted to replace the fasteners when reinstalling my receiver hitch. I was shocked at the price of a fastener kit from e-trailer.com - $45 for 6 1/2 bolts. 4 of them simply carriage bolts through a small piece of plate steel to allow blind installation.
I just drilled a 9/16 hole in some scrap steel and pressed in 610-289 wheel studs. They'll do. $12 and done.
Old Apr 17, 2015 | 10:37 AM
HuntinBronc's Avatar
HuntinBronc
Back to the Brakes - and what not to do
Here is why you don't heat a brake line - ever! I had this off, cut with about 8" of rubber line and about 1/2" of steel line. Clamped in vise. Heated - bang! I read the advise not to heat it, but thought that was with it on the car and connected. Nope, you don't heat these no matter what!
Old Apr 21, 2015 | 04:48 PM
Toyman's Avatar
Toyman
Nice work on the bronco so far. Keep up that nice work.
Side not, and not trying to hijack the thread. Where abouts are you in the UP? I am down by GR. Scroll down in the chapter threads and look up the Michigan chapter. I will also have some parts available and know a few guys that have some parts. I am gathering parts to do my frame off in a year or 2.
Old Apr 22, 2015 | 08:59 AM
HuntinBronc
In the UP, I hang out in the Houghton/Hancock and Kenton area. Down state, I hang out in Dearborn and Jackson.
Old Apr 22, 2015 | 09:37 AM
HuntinBronc
Brake Lines and Fuel Lines are in!
Hard lines were from JBG - happy with them. Everything else went in real nice. The junction block on the front axle took a little fiddling with in terms of mounting it to the axle, but I think it will work.
The bushing fit the whole, but thickness was not right to allow a clip. We'll see if it stays put.
I was worried about how the line would flex, don't want it getting out of shape and into the front prop shaft.
Fiddling to mount to axle
Plug and play - lines from JBG plumbed in nice...needed to remove prop valve to get new fuel line positioned.
Everything mounted up nice and tight
Old Apr 22, 2015 | 09:39 AM
HuntinBronc
Out of the Garage with wheels and tires cleaned up
Old Apr 22, 2015 | 09:41 AM
HuntinBronc
Got the horses all out in the pasture
Who ever said Broncos and Mustangs can't get along?
Old Apr 30, 2015 | 09:39 AM
ford_pickup's Avatar
ford_pickup
Beautiful Truck
Old May 1, 2015 | 08:58 PM
HuntinBronc
Thank You!
Old Aug 6, 2015 | 03:09 PM
HuntinBronc
For those who might have missed it, JBG now has replacement fuel tank skid plates for our full size Broncos. They look very nice, but not original.
Old Aug 8, 2015 | 03:24 PM
bigzirb's Avatar
bigzirb
Just wondering what you used for fuel lines? The Bronco is looking great.
Old Aug 11, 2015 | 09:34 PM
HuntinBronc
BigZirb - Fuel lines (2pc) were from JBG = Jeff's Bronco Graveyard
Old Jan 12, 2016 | 08:16 PM
  #28
HuntinBronc
Okay - been plugging away and need some help. Bought patch panels to fix my quarters and I think they are wrong. The don't have the shape (flare) the originals had at the wheel arch. How is this possible?
Old Jan 12, 2016 | 08:32 PM
  #29
HuntinBronc
This is the drivers side quater showing the gap when I drop a straight edge from 12 o'clock on the wheel arch up to the first character line.
Old Jan 12, 2016 | 08:34 PM
  #30
HuntinBronc
This is the passenger side with patch panel in...notice, there is NO gap...thus NO flare. This kind of sucks. Does anyone know where I can get patch panels that have the correct flare? I am keeping my front fenders, want the quaters to match.
