06 Expedition Alternator
Old Feb 20, 2015 | 06:47 AM
Domino's Avatar
Domino
How do I determine which alternator I have in an 06 Expy Limited ? Evidentally there is a 110 amp and a 130 amp in that model year. Any thoughts ??
Thanks in advance for your time...
Old Feb 20, 2015 | 07:04 AM
Skauber's Avatar
Skauber
I'm not 100% sure, but if you're replacing it I think they're interchangeable, and I'd get the stronger 130 amp one if I were replacing it. Don't think it's much of a difference in price either. Not sure how you will be able to check which one is one there already, perhaps you can look around it and try to find a part number on it.
Old Feb 20, 2015 | 08:56 AM
Lloyd78's Avatar
Lloyd78
If it is like the 03's they are interchangeable so I went to the 130 amp.
Old Feb 20, 2015 | 11:31 AM
alloro's Avatar
alloro
Look for the part number on the alternator, it can be determined from that. Also, I believe if it has the factory navigation system then it comes with the 130 amp alternator. Without it you get the standard 110 amp one.
Old Nov 15, 2023 | 04:48 AM
matt65557's Avatar
matt65557
1st Gear
if you have built in nav its usually the higher amp
TAT2DUP81
Mar 2, 2018 02:15 PM
waldreps
2004 - 2008 F150
Aug 13, 2017 09:53 PM
Avanti
Electrical Systems/Wiring
Aug 24, 2004 02:13 PM
judge1971
Jun 25, 2004 02:05 PM
