Boost. VGT duty cycle(make sure turbos functioning properly). IPR duty cycle. FICM main power(looks like the logic board is right with your alt./ battery voltage which is good). a mechanical Fuel press. gauge is always a good idea. Make sure EOT and ECT stay within 20degrees. hmm.. that's a good start
well i got some data on the way to work from my livewire. my ect and eot stay at or around 180. my tranny is around 165. icp is 500-600 at idline and never seen it go above 3000. ficm start up is 14. what else is important to monitor?
A Couple numbers you should clarify. First ficm start up at 14? Also the 180 oil and coolant is a bit low what temps are you driving in?
Yep my everyday set up is ect,eot,ficm volts, and system volts and scroll through and look at icp, ipr, vref, and ebp every now and then just to check on things. Thats on my scangauge. If im having a question on something else I plug in the torque pro and look at pretty much everything (6 pids per view) I think I have 6 or 7 screens worth set up right now.
i meant 190. and ficm is at 12 before starting and jump to around 13-14 after i start itis a 58v ficm as well
If your saying your ficm is sitting at 12 and 13 volts with koeo you have issues. What does it read when you start. It need to be some where about 47 or so.
it says ficm ignition in my livewire ficm volts is at 54
also i had the old livewire and it through codes for the egr delete and the upgraded ficm but my new one doesnt at all does anyone know what could cause this?
The logic side of the FICM will be battery or charging voltage. He said main power is 58v. IPR at idle should be 22-27%. VGT is probly gunna be 40-60% at idle but should cycle from 15%-85% when idling for a while depending on pcm software. Always keep an eye on battery and charging voltage.
