Hey guys, you have been a huge help getting me going on getting my dad's ford 77 f250 truck up and running. The problem now is the timing is about a half inch off (timing light used) and the rotor is COMPLETELY stuck.
I've put over a weeks worth of bust rust on the rotor, and tried channel locks, trying prying upwards, and nothing.
What's going to be the best way to get this thing off or loose to adjust the timing? Can I actually pry upwards? Should I try something else?
Try a pry bar and yes pry up. But work from side to side
and get it to rock a bit. Rust is not your friend here. I have
had to break them and use heat to remove some. Also as a lube
like panther **** stuff I use a 50/50 mix of acetone and ATF.
But you would have to pull the dizzy to get t to run down inside
for any kind of panther **** to work. It don't run up hill well.
It is not really a rotor, but more a stuck distributor. A rotor implies a wheel brake rotor....
Anyway yes try the 50/50 from above then PB blaster and maybe "Freeze off". If a small pipe wrench will not fit, then try a sink/faucet basin handle lock nut wrench. Careful prying or beating on it, it can break.
Then....you have to drop the pan and tap from below...Once you get it, take it all the way out clean up the area and come reinstall time use some anti-seize compound.
Break the rotor (as in cap and rotor)! should be cheap and easy to aquire new.
If it's the signal wheel under it, then... uhm... I donno...
Brake Rotors, use a large Variable Swing Press! and replace wheel studs...
Distributor? pry carefully between it and block, maybe a strap wrench to twist it... or use the BFH (Variable Swing Press used for brake Rotors) and aquire a new or junkyard one...
I'm not really nice when I'm working on my junk, so you may want to listen to the guys above
Edit: maybe post some pictures to see what your talking about? I like using http://imgur.com myself...
I have conquered a couple of rotors in the past by "splitting" them where they fit over the distributor shaft. A paper towel or rag for debris under the rotor and then a die grinder with a cutoff wheel to cut the side of the rotor.Make a cut that does not go all the way to the steel shaft,insert a screwdriver in the cut slot and twist sideways with the screwdriver. It should pop open & break(separate) the binding parts ( cut a slot on both sides if needed). No die grinder? Same process with a hand held hacksaw blade. I don't know if there is enough up and down room for a full fledged hacksaw.Cut vertically up and down until you have relieved the pressure or can break the bottom of the rotor away from the shaft. Use a little caution & there will be no damage to anything aside from the actual rotor. Good luck! Gary
