New excursion owner
Old Feb 19, 2015 | 06:55 PM
  #31
harley4jcs's Avatar
harley4jcs
Originally Posted by Suzuki357
I just left a popular truck shop in my area and the guy was telling me some ppl stack the blocks like that so they still have a bump stop when towing heavy but he recommended swapping it to a single block. I'll look into that B mod spring swap. She has 125k miles
Sweet, she's just broke in..
Old Feb 19, 2015 | 06:56 PM
  #32
Suzuki357's Avatar
Suzuki357
Originally Posted by WE3ZS
Hey Zuk, sorry to say but that is about the worst setup for heaving towing in that picture. First off stacked blocks are a major no no in most folks opinions, and I share that opinion to an extent. What I see that's worse is the total of about 5" of blockes sitting under the super weak EX stock spring pack, that is not good and it's pretty bad if you want to tow especially a heavy tow! In your pic do you see that bottom half leaf that only goes forward? It's a factory installed "slapper style" traction bar that Ford put there because the rear springs are so weak that they allow axle wrap under hard acceleration (or heavy pulls).
The problem is that Ford marketed the EX to soccer moms and because of that targeted audience they gave them soft springs that rode 2" lower than their cousin Super Duty pickups. The shorter springs allowed the EX to fit into more residential garages and the mushy springs gave the soccer moms a cushier ride.
When my EX was still all stock I towed our 9500lb toyhauler and it was nearly undeliverable, the high TH tongue weight (even with a 1200lb WD setup) would push the rear of the EX around so bad it would try to change lanes on downhill curves. Not fun. I think you should take the small TH out for a test tow in your local area before the first trip just to see what you have as a starting point.
Now do you think air bags and a 1 piece block would help that? I know exactly what you mean by the mushy ride and the trailer pushing the truck around. Had the same problem with a stock f150 fx2 towing 8k but the bags cured that
Old Feb 19, 2015 | 07:03 PM
  #33
WE3ZS's Avatar
WE3ZS
I'm sure it would be better but I don't how much better........ The bags will cetainly help to support the load but I don't know if or how they would impact the axle wrap and rear steer from the trailer pushing the rear around.
Old Feb 19, 2015 | 07:55 PM
  #34
Suzuki357's Avatar
Suzuki357
So I guess I need to be looking into B code springs asap. That's pre 04 f250 right? Im thinking they can't be too expensive and shouldn't be hard to find either
Old Feb 20, 2015 | 12:31 AM
  #35
Apocalypse's Avatar
Apocalypse
Originally Posted by harley4jcs
WOW, it only took you 5 post to to use your ONLY allotted type-o. If you have another you'll be BAND for life . OH S*** did I hit send ??
Damnit Harley, not you too! I hate to see you go man but the rules are the rules It's banned for life, not band. Drop off your keys and badge on the way out.
Old Feb 20, 2015 | 06:33 AM
  #36
WE3ZS's Avatar
WE3ZS
Actually it's up to about '07 or so, I think it was in '08 when they started to put the longer rear leaves on the pickups. B code or C codes are a great option, I run the Bs with the common mod of the thicker in between leaf spacers and the bottom 2 EX leaves added to the B pack. In addition to that I also use the taller tapered blocks (approx. 4") from an F-350 and for a little extra lift I then cut my stock traction bar up and used 2 sections of it between the pack and blocks. This setup on my EX gave me just over 4.5" of lift and made the whole towing experience worlds better!
Old Feb 20, 2015 | 07:27 AM
  #37
harley4jcs's Avatar
harley4jcs
DANGED I thought the to to would have done it ..
Old Feb 20, 2015 | 11:13 AM
  #38
Suzuki357's Avatar
Suzuki357
I've got some researching to do. I'm thinking about keeping stock spring and adding air bags and a track bar so I can keep a smooth ride then air up the bags when it's time to tow
Old Feb 20, 2015 | 11:25 AM
  #39
harley4jcs's Avatar
harley4jcs
The truck weights 7000 LBs EMPTY. It rides & drives GREAT with the B-MODs
Old Feb 20, 2015 | 02:04 PM
  #40
Suzuki357's Avatar
Suzuki357
That's a good point. I forgot what a heavy pig this thing is. I found a set of used springs off an 04 f250 for $200. Anything I should be looking for when I go check these things out?
Old Feb 20, 2015 | 02:27 PM
  #41
WE3ZS's Avatar
WE3ZS
If the donor truck is still around you can verify the spring code by checking the door sticker, under springs it will have something like "VVBB" showing that the truck was built with V codes up front and B codes in back.
Just look for cracks in the leaves and overall general condition, they may or may not have a top overload leaf. If they do you will be removing it anyway to protect your rear AC lines and then some of the goofballs here use that top overload leaf as an extra leaf added to their front springs.
This shot shows one of my stock B codes pre-mod at the top, then one of the stock X code fronts in the middle and the bottom spring pack is my modded X code with the top overload from the B codes added to the pack.
Old Feb 20, 2015 | 11:36 PM
  #42
The2003Excursion's Avatar
The2003Excursion
You may also want to know that your hitch is rated @ 500/5000 LBs
This is what mine says
Old Feb 21, 2015 | 08:09 AM
  #43
harley4jcs's Avatar
harley4jcs
NOW That's what I'm talkin about 12/12 on a straight pull
Old Feb 21, 2015 | 08:58 AM
  #44
A Rodder's Avatar
A Rodder
CURT 14011 fits all eEX's
Old Feb 21, 2015 | 09:31 AM
  #45
harley4jcs's Avatar
harley4jcs
My Account|
Order Status
Help
<section class="searchBarSection">
  • (800) 874-8888
  • <form name="headerSearchForm" id="headerSearchForm" action="javascript:submitSearch();" method="get" novalidate="novalidate"><input name="searchTerm" class="validate[funcCall[validateSearchTerm]] searchInput defaultInput watermark" id="searchTerm" type="text" maxlength="75"><input class="buttonLeft" type="submit" value="Go">
    </form>
</section>
  • <nav class="performanceNav navMenu positioned" style="left: 0px; top: 58px; display: none;">
    1. Air Filters
    2. Air Intake Systems
    3. Batteries
    4. Brakes, Rotors & Pads
    5. Cooling Performance
    6. Drivetrain & Differentials
    7. Engines & Components
    8. Exhaust, Mufflers & Tips
    9. Fuel Systems
    10. Gauges
    11. Ignition Systems
    12. Motor Oil & Oil Filters
    13. Performance Chips & Programmers
    14. Pulleys
    15. Shifters
    16. Superchargers & Turbochargers
    17. Suspension Systems
    </nav>
  • <nav class="exteriorNav navMenu" style="display: none;">
    1. Bed Caps & Bed Rails
    2. Bike Racks
    3. Billet Grilles
    4. Body Armor & Protection
    5. Body Kits
    6. Bumpers
    7. Car Bras
    8. Car Covers
    9. Chrome Accessories
    10. Deflectors
    11. Fender Flares & Trim
    12. Grille Guards & Bull Bars
    13. License Plate Frames
    14. Lights
    15. Mud Guards & Mud Flaps
    16. Nerf Bars & Running Boards
    1. Roof Racks & Cargo Carriers
    2. Side View Mirrors
    3. Ski & Snowboard Racks
    4. Soft Tops & Hard Tops
    5. Tires
    6. Tonneau Covers
    7. Trailer Hitches
    8. Truck Bed Accessories
    9. Truck Bed Liners
    10. Truck Racks & Van Racks
    11. Truck Tents
    12. Truck Toolboxes
    13. Wheels & Rims
    14. Winches
    15. Wiper Blades
    </nav>
  • <nav class="interiorNav navMenu" style="display: none;">
    1. Car Audio
    2. Cargo & Trunk Liners
    3. Dash Covers
    4. Dash Kits
    5. Floor Mats & Liners
    6. Rear View Mirrors
    7. Seat Covers
    8. Seats
    9. Steering Wheel Covers
    10. Windshield Shades & Covers
    </nav>
  • <nav class="accessoryNav navMenu positioned" style="left: 367px; top: 58px; display: none;">
    1. ATV & Motorcycle Accessories
    2. Auto Detailing Supplies
    3. Automotive Logo Gear
    4. Boat & RV Accessories
    5. Car Horns
    6. Garage Accessories
    7. Gas Saving Products
    8. Man Cave
    9. Mobile Electronics
    10. Pet Travel
    11. Radar Detectors
    12. Ramps, Jacks, Stands & Creepers
    13. Sports Logo Gear
    14. Tailgating Accessories
    15. Tire Accessories
    16. Tools & Tool Storage
    17. Travel Accessories
    18. Winter Driving Accessories
    </nav>
  • <nav class="specialtyNav navMenu" style="display: none;">
    1. Gift Guide
    2. Products Under $100
    3. Promo Zone
    </nav>
  • 2000 Ford Excursion (see all products) Change Vehicle
    <select class="vehicleYear defaultSelect" id="vehicleYear"><option value="0">Select Year</option> <option value="2016">2016</option> <option value="2015">2015</option> <option value="2014">2014</option> <option value="2013">2013</option> <option value="2012">2012</option> <option value="2011">2011</option> <option value="2010">2010</option> <option value="2009">2009</option> <option value="2008">2008</option> <option value="2007">2007</option> <option value="2006">2006</option> <option value="2005">2005</option> <option value="2004">2004</option> <option value="2003">2003</option> <option value="2002">2002</option> <option value="2001">2001</option> <option selected="selected" value="2000">2000</option> <option value="1999">1999</option> <option value="1998">1998</option> <option value="1997">1997</option> <option value="1996">1996</option> <option value="1995">1995</option> <option value="1994">1994</option> <option value="1993">1993</option> <option value="1992">1992</option> <option value="1991">1991</option> <option value="1990">1990</option> <option value="1989">1989</option> <option value="1988">1988</option> <option value="1987">1987</option> <option value="1986">1986</option> <option value="1985">1985</option> <option value="1984">1984</option> <option value="1983">1983</option> <option value="1982">1982</option> <option value="1981">1981</option> <option value="1980">1980</option> <option value="1979">1979</option> <option value="1978">1978</option> <option value="1977">1977</option> <option value="1976">1976</option> <option value="1975">1975</option> <option value="1974">1974</option> <option value="1973">1973</option> <option value="1972">1972</option> <option value="1971">1971</option> <option value="1970">1970</option> <option value="1969">1969</option> <option value="1968">1968</option> <option value="1967">1967</option> <option value="1966">1966</option> <option value="1965">1965</option> <option value="1964">1964</option> <option value="1963">1963</option> <option value="1962">1962</option> <option value="1961">1961</option> <option value="1960">1960</option> <option value="1959">1959</option> <option value="1958">1958</option> <option value="1957">1957</option> <option value="1956">1956</option> <option value="1955">1955</option> <option value="1954">1954</option> <option value="1953">1953</option> <option value="1952">1952</option> <option value="1951">1951</option> <option value="1950">1950</option> <option value="1949">1949</option> <option value="1948">1948</option> <option value="1947">1947</option> <option value="1946">1946</option> <option value="1945">1945</option> <option value="1944">1944</option> <option value="1943">1943</option> <option value="1942">1942</option> <option value="1941">1941</option> <option value="1940">1940</option> <option value="1939">1939</option> <option value="1938">1938</option> <option value="1937">1937</option> <option value="1936">1936</option> <option value="1935">1935</option> <option value="1934">1934</option> <option value="1933">1933</option> <option value="1932">1932</option> <option value="1931">1931</option> <option value="1930">1930</option> <option value="1929">1929</option> <option value="1928">1928</option> <option value="1927">1927</option> <option value="1926">1926</option> <option value="1925">1925</option> <option value="1924">1924</option> <option value="1923">1923</option> <option value="1922">1922</option> <option value="1921">1921</option> <option value="1920">1920</option> <option value="1919">1919</option> <option value="1918">1918</option> <option value="1917">1917</option> <option value="1915">1915</option> <option value="1914">1914</option> <option value="1913">1913</option> </select><select class="vehicleMake defaultSelect" id="vehicleMake"><option value="0">Select Make</option> <option value="5">Acura</option> <option value="66">Aston Martin</option> <option value="7">Audi</option> <option value="83">Avanti</option> <option value="72">Bentley</option> <option value="8">BMW</option> <option value="47">Buick</option> <option value="2">Cadillac</option> <option value="115">Chevy</option> <option value="12">Chrysler</option> <option value="40">Daewoo</option> <option value="23">Dodge</option> <option value="43">Ferrari</option> <option selected="selected" value="6">Ford</option> <option value="24">Geo</option> <option value="116">GMC</option> <option value="10">Honda</option> <option value="45">Hummer</option> <option value="34">Hyundai</option> <option value="30">Infiniti</option> <option value="37">Isuzu</option> <option value="62">Jaguar</option> <option value="33">Jeep</option> <option value="14">Kia</option> <option value="80">Laforza</option> <option value="70">Lamborghini</option> <option value="86">Lancia</option> <option value="32">Land Rover</option> <option value="13">Lexus</option> <option value="41">Lincoln</option> <option value="68">Lotus</option> <option value="69">Maserati</option> <option value="26">Mazda</option> <option value="21">Mercedes-Benz</option> <option value="18">Mercury</option> <option value="120">Mini</option> <option value="27">Mitsubishi</option> <option value="64">Morgan</option> <option value="9">Nissan</option> <option value="38">Oldsmobile</option> <option value="20">Plymouth</option> <option value="16">Pontiac</option> <option value="4">Porsche</option> <option value="124">Qvale</option> <option value="67">Rolls Royce</option> <option value="22">Saab</option> <option value="36">Saturn</option> <option value="28">Subaru</option> <option value="31">Suzuki</option> <option value="17">Toyota</option> <option value="11">Volkswagen</option> <option value="25">Volvo</option> </select><select class="vehicleModel defaultSelect" id="vehicleModel"><option value="0">Select Model</option> <option value="182">Contour</option> <option value="411">Crown Victoria</option> <option value="351">Econoline</option> <option value="197">Escape</option> <option value="187">Escort</option> <option selected="selected" value="417">Excursion</option> <option value="170">Expedition</option> <option value="10">Explorer</option> <option value="174">F-150</option> <option value="21">F-250</option> <option value="670">F-350</option> <option value="1453">F-450/550</option> <option value="16">Focus</option> <option value="436">Freestar</option> <option value="60">Mustang</option> <option value="169">Ranger</option> <option value="43">Taurus</option> <option value="134">Thunderbird</option> <option value="236">Windstar</option> </select>
<!-- Offer Id: 114202 -->
<!-- Offer Id: 57765 --><!-- Offer Id: 46334 --> <!-- Offer Id: 103845 -->
<section class="siteStripeSection" id="siteStripe"><map name="siteStripeMap"><area href="http://www.autoanything.com/Checkout/cart?icid=SiteStripe:LonePixel" shape="rect" coords="480,0,960,50" alt="Click for Exclusions"><area href="http://www.autoanything.com/Checkout/cart?icid=SiteStripe:LonePixel" shape="rect" coords="0, 0, 960, 50"></map></section>
<article class="hidden headerShippingButtonContent" id="headerShippingButtonContent">Free Shipping – No Minimum Purchase
Get Free Shipping on qualified items without hidden fees. AutoAnything has Free Shipping everyday on more than 99% of our products, saving you some valuable cash on accessories. Valid on shipments to the contiguous U.S. Additional restrictions may apply. See Details
</article> <article class="hidden headerDefaultPromoButtonContent" id="headerDefaultPromoButtonContent">We guarantee you the lowest price! You have one full year of price protection from the date of your purchase.</article> <section class="pageBody"><section class="section cartMainSection fullWidthLiteGrid " id="cartMainSection"><section class="checkoutProgressIndicator" id="checkoutProgressIndicator">1Shopping Cart
2Billing & Shipping Address
3Summary & Payment
Receipt
</section> Shopping Cart
<section id="cartDisplay"> <form id="enterShippingZipCode"><label for="shippingZip">Where do you want your item(s) shipped?</label> <input name="shippingZip" class="defaultInput shippingZip validate[required,custom[zip]]" id="shippingZip" type="text" placeholder="Zip Code..." value=""><input class="buttonLeft" type="submit" value="GO">
</form>See below for expedited shipping options for , See below for costs of shipping, duties and tariffs to , (Change)
Sorry, we were unable to calculate shipping rates based on the zip code you provided. Please call (800) 874-8888 for further assistance. (Change)
    • Item
    • Qty
    • Price
    • Shipping
    • Total
      • CURT Receiver Hitches
      • Class IV Square Tube Hitch - Exposed
      • <label class="mainCartItemLabel">Color/Style</label>Black/Receiver Hitch Only
      • <label class="mainCartItemLabel">Vehicle</label>2000 Ford Excursion
      • <label class="mainCartItemLabel">Submodel</label>All Excursion mdoels
      • <label class="mainCartItemLabel">AutoAnything SKU</label>4000935
      • <label class="mainCartItemLabel">Part Number</label>14011
      • 20% off Orders of $99 or More with Code 20WELCOME
    • <form class="updateCartItemQuantityForm" id="QuantityUpdate_117406863" action="javascript:cartItems.updateQuantity(117406 863, 8, 0);"><input class="defaultInput validate[required,custom[integer],min[0],max[99]] quantity" id="cartItemQuantity_117406863" type="text" value="1">Update</form>Remove
    • $231.99
      -$46.40
      $185.59
      • Ships by 02/23/2015
        via FEDEX Home Delivery - Free
      • <form class="zipCodeContainer inlineContentSection" id="UpdateZipCodeForm_117406863"><label class="inlineContentSection shipSoonerLbl" for="ItemLevelZipCodeInput_117406863">Get it Faster!</label> <input name="ItemLevelZipCodeInput_117406863" class="defaultInput shippingZip shipSoonerInput validate[required,custom[zip]] inlineContentSection" id="ItemLevelZipCodeInput_117406863" type="text" value=""> <input class="buttonLeft" type="submit" value="GO">
        </form>
    • $185.59
    • $231.99 <label class="mainCartItemLabel">Subtotal</label>
    • -$46.40 <label class="mainCartItemLabel">Total Savings</label>
    • TBD <label class="mainCartItemLabel">Shipping</label>
    • <text>$0.00</text> <label class="mainCartItemLabel">Tax </label>
    • $185.59
</section></section></section>
inthedirt
Jul 22, 2017 08:59 PM
defekticon
Feb 8, 2014 12:57 PM
davinci99
Jan 1, 2011 11:12 AM
f150buggy
Aug 3, 2010 10:45 AM
gr8scott72
Nov 11, 2008 12:58 PM
