how hard to pull the bed?
Old Feb 20, 2015 | 11:10 AM
  #31
Diesel_Brad's Avatar
Diesel_Brad
Rust really has nothing to do with it.
the SD speed clips have no threads and the bolts are self tapping. They kind weld themselves together.
I lost count to how may BRAND NEW trucks had the clips brake that needed the bolts Burned off. The joys of working at a body company
Old Feb 20, 2015 | 01:19 PM
  #32
tjc transport's Avatar
tjc transport
i ain't rite
yup. that is the only thing i hate about the new bed bolts.
99% of the time you have to cut them off, even if they were just put on yesterday.
Old Feb 20, 2015 | 07:19 PM
  #33
ncranchero's Avatar
ncranchero
Never messed with a SD. I'm speaking of F150 parts. Frame U-nuts come threaded, as shown. Had them on a couple 97-04 models,off/on w/no problem. That's why I used them on my '94. To each his own.
Old Feb 21, 2015 | 04:14 AM
  #34
Diesel_Brad
same bolts. I am VERY surprised you haven't had any issues
Old Feb 21, 2015 | 07:33 AM
  #35
ncranchero's Avatar
ncranchero
Figured they were. Not much rust here as we don't get much frozen precipitation/salt. I've had to put a pipe on a pull bar to loosen a couple because my IR impact wouldn't loosen them.
Old Feb 21, 2015 | 02:07 PM
  #36
Diesel_Brad
..... I've had to put a pipe on a pull bar to loosen a couple because my IR impact wouldn't loosen them.
Same here. Then the clips snaps off and just spins
Old Feb 21, 2015 | 02:17 PM
  #37
tjc transport
i ain't rite
normally what happens with me is the torx driver breaks.
Old Feb 21, 2015 | 02:19 PM
  #38
Diesel_Brad
LOL, that too
Old Feb 21, 2015 | 02:25 PM
  #39
ncranchero's Avatar
ncranchero
Don't jinx me Brad !!!
Old Feb 21, 2015 | 02:43 PM
  #40
FlatbedAndy's Avatar
FlatbedAndy
LOL, that too
Hey Brad, check out the seats in this one :1997 Ford F250 LB 4x4 7.3L Power Stroke Diesel
Old Feb 21, 2015 | 03:59 PM
  #41
Diesel_Brad
OK< check out the seats in this one. What is your point?
Old Feb 21, 2015 | 10:19 PM
  #42
FlatbedAndy
Just thought you'd get a kick outa seeing those BLUE 40 20 40 seats
Old Feb 22, 2015 | 07:54 AM
  #43
Diesel_Brad
I see a set of them every day in one of my trucks
Old Feb 22, 2015 | 09:04 AM
  #44
kawamatt2's Avatar
kawamatt2
The problem with SuperDuty bolts is the clip brakes and then you are SOL because you can't even hold it with a wrench.
No. Look again at the picture. If the nut is stuck to the bolt such that the nut breaks free from the clip you only have to put a wrench on the nut and turn the bolt out from above. Do you not see that the bolts thread into a nut?
Right, until you put a wrench on the nut.
Are you using the proper Torx Plus driver? If you look closely, you can see that is an OTC TP-50 driver and has thicker edges than the typical T-50 driver.
Old Feb 22, 2015 | 09:08 AM
  #45
Diesel_Brad
Those are NOT stock SuperDuty clips. Those are some variant in the aftermarket
