Smog component question
Old Feb 17, 2015 | 02:09 PM
bigyellerdawg1991's Avatar
bigyellerdawg1991
Does the EFI/computer have anything to do with the smog components on the 87-96 F150s? Or are they two seperate systems?
I've got a build in mind for my 94 using one of those aftermarket plug-and-play EFI systems, but wasn't sure how the smog stuff, like the egr, coffe can looking canister, smog pump (if applicable) tied into the whole thing.
I would like to be able to pass inspection without issues is why I'm asking.
Old Feb 17, 2015 | 11:51 PM
ZarK-eh's Avatar
ZarK-eh
Can your inspection place make exceptions for aftermarket EFI?
It's doable to swap the computer, and for the early Ford EFI's this makes a great idea! Because the early types would run batch fired injection where 2 banks of 3 cylinders would fire wasting all sorts of fuel which required that air pump to burn the wasted fuel in the catalytic converters.
When I build my '78, I used a lot of the '96 harness for the VEMS. The '96 distributor doesn't have any advance or Ignition module. I epoxied a magnet and HALL sensor into the cap and rotor for cam sync, and wired the signal output to the EFI for triggering. Timed it to 60* BTDC and *poof* works ;D I now have a chyrsler wasted spark coil from a minivan and dual platinum spark plugs which in theory should run a long time. And a GM MAP sensor out of a Renix Jeep, and VM Beetle Wide Band O2 Sensor, and a slew of other junkyard pickings... Plan to utilize a flex fuel sensor when one becomes available in the junkyard and maybe a MAF sensor.
I plan on using EGR, and the coffee can (Vacuum reservoir for various vacuum thingies like heater controls), my rebuilt has the none smog head as I am not dumping fuel into the engine. Not sure if there are any detrimental effects to this, maybe increase the chance of a cracked head? I donno... I cannot fathom why ford engineers would dump so much fuel in just to burn in t he catalytic converters, but hoping it's not an important reason.
Using an aftermarket EFI has a lot of rewards, but does come with a great wall of learning.
Last edited by ZarK-eh; Feb 17, 2015 at 11:56 PM. Reason: words and formatin'... turd times the charm!
hairyboxnoogle
Sep 21, 2018 06:51 AM
spyder0382
Dec 19, 2014 09:16 AM
One Sock
Mar 23, 2011 09:06 PM
78'Ranger
Jan 10, 2008 01:50 AM
kane
Oct 1, 2004 12:11 AM
