2004 Navigator Liftgate won't open/close
I have 2004 Navigator with low mileage (61k) and recently we had a crazy cold weather up in northeast. I don't know if that's what it caused, but since 2 days ago, my car's liftgate won't open/close automatically.
I figure the 'hook' at the center of the gate isn't 'hooking' whenever the gate closes.
Can someone give me a tip how to fix it?
thanks!
thanks!
Yes that's the one. Look at fuses #5, #30, #102, #105, and #110. Those all in some way relate to the power liftgate circuits. Take a look at the images below which show comparisons of good versus blown fuses.
Car parts stores, Wal-Mart, hardware stores, CVS, Walgreen's, local convenience stores, just about anywhere. Just make sure you replace any blown ones with an identical amperage rating/color.
To be sure, you can also beep it out with a multimeter, if you know how to. That will confirm that it has continuity, as in rare cases the fuse might look fine but there's no continuity through it, it has happened to me before, and I know others who ruled out fuses and started swapping parts, and you can imagine the look on their face when they found out it was a blown fuse when it still didn't work...
Okay, just checked all those numbers in fuse box. Everything is okay except #110. The manual says #110 controls the running board at the bottom of the doors for extra step.
My car purposely disabled that because being 10yr old, it started get rusty and about to fall off every time the running board came out when we open the car doors. So we went to local shop to disable it. I guess he 'cut' the fuse on purpose so it doesn't come out anymore. I know this isn't the issue because we disabled this feature over a year ago and the liftgate was working just fine up until few days ago.
So... besides fuse issue, what'd be my next step?
aroc126
1997-2006 Expedition & Navigator
03-05-2012 05:31 PM
cavscout075
2004 - 2008 F150
02-05-2010 03:45 PM
