Been thinking long and hard on what wheels I want to put on my 59 F250. It currently has tubeless 7.50 x 16 on tubeless style 16" wheels. I really like the look of the older lock ring style 16" wheels. (had them from the factory on my 77 F250 way back when). So I have started looking for 5 of the lock ring 16" wheels. No luck locally so far, but I just started looking. I know lock ring style are old fashioned, but so am I. Anyone know of any of them around?
I have 4 16' but they are duel style wheels off of a 59 ford box van that was junked. They were on the rear so probably won't work on F 250 front hubs because of the offset.
I don't have your wheels, but can maybe help you find a set. The stock SRW 16" x 5.5" semi drop center two part wheels, having 9/16" offset, in 1959 and later were either of two Budd Company products. They are #78370 having a Goodyear LTS style outer rim, or #60880 having a Firestone RHP outer rim. Both would have been sold under Ford number 8J 1007. The National Wheel and Rim Association (NWRA) cross reference code for them is X-45045. They were also used by Dodge and Studebaker. I also find a later Kelsey-Hayes reference showing K-H #82473 also crosses to X-45045, but that reference doesn't say which outer rim was fitted. I also find a later reference showing X-45142 used on 68/69 F-250s.
Salvage yards subscribe to on-line inventory networks which should be able to use these numbers to simplify your search. Stu
On the original topic, the real reason the two part tube type wheels remained an option along side the tubeless varieties was strength. Higher load capacity. Stu
Be warned - very few tire shops will even touch these wheels anymore. Rightly or not, they have a reputation for being dangerous to work on. I still have my original 17" split rims with 7.50 17 bias ply mud grips, but I keep them in the barn & will only run them when I need my truck to look 100% original.
Yes, in part I agree. But not completely. Your 17" wheels have a different rim design than the 16" ones discussed here. Because yours are 17" I know they have an outer rim called the "widow maker". The technical term for them is Firestone RH-5°. All multi-part wheels need special handling, but the widow makers can't be trusted. Stu
The general "consumer type" tire shops generally will not work with a lock ring wheel, but the commercial dealers that regularly handle tires for medium and heavy truck do not seem to have a problem with them.
