diesel
Old Jul 22, 2003 | 10:04 PM
travis c's Avatar
travis c
diesel
what would be the easiest deisel to put into a 77 f100 2wd with a 351m?
Old Jul 22, 2003 | 11:46 PM
Pentekno2's Avatar
Pentekno2
diesel
This question belongs in the 73-79 Forum.
-Daniel
Old Jul 23, 2003 | 02:34 AM
Torque1st's Avatar
Torque1st
Posting Legend
diesel
Travis, turn your email on! Set it to "show email". Other users can not see your email address.
Old Jul 24, 2003 | 12:34 PM
Scot's Avatar
Scot
diesel
Easiest would probably be the 6.9/7.3 IDI engines. Biggest problem in an F100 will be the weight. Seems like they weigh ~900 lbs + accessories.
Old Jul 24, 2003 | 05:24 PM
muscletruck7379's Avatar
muscletruck7379
diesel
i was planning on asking the same question. but more specifically what about stuff like engine mounts, bellhousings and front springs the only difference of mine is that it is for a 73 f250 highboy 4x4
Old Jul 24, 2003 | 10:03 PM
Txquadhunter24's Avatar
Txquadhunter24
diesel
The hardest part will probably be is finding the frame mounts for these year of trucks, 84 was the first year offered. Don't quote me on this But i've heard the 460 has the same frame mounts as the Diesel, But i'm unsure of it. As far as the easiest Diesel swap Would be the 6.9 orf the early 7.3's before turbo was added. After The 7.3/PSD It takes alot of the Wiring from inside the truck before the Motor will run, I read this on a post awhile back, Try doing a search on Diesel swaps i'm sure ya can find the one with all the wring info needed to swap in a Late model diesel. But the 6.9 with be the easist to do.
Old Jul 24, 2003 | 10:33 PM
Matts72's Avatar
Matts72
diesel
You need to be more concerned with beefing up the front suspension. That diesel weighs a lot. The 460 weighs about 760 pounds. The 6.9 weighs about 900 pounds and the 7.3 weighs even more.
Old Jul 25, 2003 | 01:30 PM
75f100's Avatar
75f100
diesel
try these guys.......
fordcummins.com
they scialize in what you want, they even sell kits.
Old Jul 25, 2003 | 11:28 PM
muscletruck7379
diesel
yeah my choice would be the 6.9- mostly because i alredy know of one, but it needs a fuel pump ($$$ouch$$$) maybe i'll get lucky and find one on ebay or something. and that fordcummins.com is really usefull. thanks.
Old Jul 26, 2003 | 07:42 AM
rrawlins's Avatar
rrawlins
diesel
The local Ford guy here says a Cummins. One wire hookup, lots of power, lots of acc. available.
Old Jul 26, 2003 | 09:56 AM
muscletruck7379
diesel
I wouldn't mind a cummins either it just depends on what I can find. sometimes I swear that i live hundereds of miles from what I ever need...
Old Jul 26, 2003 | 03:29 PM
hillbillyk's Avatar
hillbillyk
diesel
I picked up a 97 dodge cummins 12v turbo diesel at the local junkyard for 1000, a steal for that motor, gonna put it in a 79 f-250 supercab 4x4. They are great motors, just make sure you get a 12v motor, the 24v motors are computer controlled.
Old Jul 26, 2003 | 06:09 PM
muscletruck7379
diesel
man, the only diesels that my local junkyard has is a 6.2 chev and a 6.9 (non powerstroke) the 6.9 is only like $400 but needs a fuel pump. and the next closest junkyard is like 40 miles away. it isn't the computer or electronics that scares me from a new engine, its just the price that people want for them! what would be best for me is if I could find a new superduty that was wrecked. then i could have front and rear axles that have disk brakes!
Old Jul 27, 2003 | 11:21 AM
Scot's Avatar
Scot
diesel
I built the mounts when I did my 6.9/ '75 highboy. I took the factory flat mount plate and built the rest. It bolted to existing holes in the frame. Use the diesel bell housing and whatever tranny you want. I started with the NP 435 but the gear spacing was wrong. I swapped in a BW T19D. It was from behind a diesel and worked well. It was a bolt in except for fabbing a t/c shifter mount.
The 6.9 was pretty gutless and if I were going to do it again with a Navistar engine, it would be an early PSD or a 7.3 IDI with the last choice being a 6.9. The 6.9's have smaller headbolts and are somewhat prone to headgasket failure. The block heater tends to crack the block if used improperly. Then there is our friend, cavitation erosion which is a factor in all of these engines.
The 6.9 and 7.3 weigh the same for all practical purposes.
I saved the mounts I built and the offer is still open. They are not pretty because I built them in place. I will give you the mounts, you just pay the freight. All I ask is that you make a dimensional drawing and post it in the public domain.
Old Jul 27, 2003 | 11:23 AM
Scot's Avatar
Scot
diesel
Last 6.9 pump I bought was ~$375 from Southwest Metrofuel. They are easy to change and you just time it by lining up the marks.
